Home > General > What Did You Do In Your Full Fat Today
Page 383 of 383 <123 ... 381382383
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Fitted the new Bevinsee H7 LED 120w main beam bulbs.
Truly awesome so now fully LED front end.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #718185 19th May 2025 5:55pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Installed Unique Auto Developments (ID core) Apple CarPlay solution. Was a proper faff getting all the dash and trim off to be able to remove the head unit. However, it’s completely achievable for a novice with patience and a few photos.
Whilst I was in there, I was able to swap out the instrument cluster cooling fan that’s behind the steering column with a used one from eBay (but 3 years younger so 🤞) I’d been getting the B12FE-13 (2Cool Fan - General electrical failure - circuit open fault intermittently so hoping that solves it.
All back together again now and working perfectly. Only 3 dash fixing screws left over at the end so hope they’re not essential! 😂 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #718558 25th May 2025 1:41pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
At long last, what began as a simple front caliper refurbishment turned into a full overhaul. All the suspension arms, drop links, and steering arms have been replaced with Lemförder parts. I also re-greased and re-booted the drive shafts, new ABS sensors brake hoses etc, etc and finished with a complete coolant flush — 11 litres in total. It’s finally finished!
 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #718608 26th May 2025 11:26am
just a reminder to members that this is a 'one' post thread so please dont discuss or reply to posts as this spoils the thread..thanks.  ... - .- -.
Post #718644 26th May 2025 9:04pm
tomthespark2011
Changed the plugs and filters. Surprisingly long job.
(Rear plugs are a faff to do)
Oiled the towing socket on towbar as it stopped dropping down.
Post #718864 30th May 2025 8:39pm
AndyRoo
Finally got around to two small jobs that have been bugging me for some time.
Firstly modified the Sprinter jack with the new adapter head. Now much more stable although somewhat limits what I can use it for now.
Secondly replaced the space saver with a full sized wheel, thankfully I had the loading kit, that Defender wheel is very heavy. Thought it may be an issue with the 15mm extra offset of the Defender rim, but no problem at all.
The original space saver alloy I'll put up for sale, the tyres never been on the car, still has the paint on the tread. The date code is 3818 so this is relatively new to the car as mine is a 2012 car so I suspect the previous owner replaced the wheel & tyre some time in 2018.
Anyway, I'll put it up for sale as I don't need it anymore and the only ones I see on EBAY are crappy condition and they seem to be quite rare in as new condition. Seems this wheel is used for a variety of LR models not just the L322.
Post #718952 1st Jun 2025 6:10pm
Bbhster
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Passed the MOT with flying colours (7 June) and ordered 5 General Grabber AT3s (to be fitted on Sat 14th followed by 4-wheel alignment), new lower tailgate straps and strut & a tailgate button cover. Very Happy
Post #719402 8th Jun 2025 12:03pm
