![]() | Home > Technical (L405) > Hard brake pedal |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
If it has an auxiliary battery in the right side of the trunk, under the panel, check if it is OK, mine did this when the aux batt was gone... |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Could there be a vacuum leak affecting the brake booster?
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Excellent tip Adara, I did have the ‘gearbox fault HDC not available ‘ flash up randomly a few days ago, I believe these are signs of a failing battery, the aux battery has a date stamp of 2016 so could be on the way out, my battery tester says it’s ok but I’ll monitor it, the main battery however has a date stamp of 2020 and is only showing half charge |
I'm sure you'll sort it! best of luck. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
Mine does the same, has done since I've owned it...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
you need to put your foot on the brake pedal to start hence its in the position its in ...so its normal.. ... - .- -.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1418 ![]() ![]() |
![]() BRAKE BOOSTER COMPONENT TESTS 1. Check all hoses and connections. All unused vacuum connectors should be capped. Hoses and their connections should be correctly secured and in good condition with no holes and no collapsed areas. 2.Inspect the valve on the brake booster for damage 3. Check the hydraulic brake system for leaks or low fluid With the automatic transmission in PARK, stop the engine and apply the park brake. Pump the brake pedal several times to exhaust all vacuum in the system. With the engine switched off and all vacuum in the system exhausted, apply the brake pedal and hold it down. Start the engine. If the vacuum system is operating, the brake pedal will tend to move downward under constant foot pressure. If no motion is felt, the vacuum booster system is not functioning 4.Remove the vacuum hose from the brake booster. Manifold vacuum should be available at the brake booster end of the hose with the engine at idle speed and the automatic transmission in PARK. Make sure that all unused vacuum outlets are correctly capped, hose connectors are correctly secured and vacuum hoses are in good condition. When it is established that manifold vacuum is available to the brake booster, connect the vacuum hose to the brake booster and repeat Step 3. If no downward movement of the brake pedal is felt, install a new brake booster Operate the engine for a minimum of 10 seconds at a fast idle. Stop the engine and allow the vehicle to stand for 10 minutes. Then, apply the brake pedal with approximately 89 N (20lb) of force. The pedal feel (brake application) should be the same as that noted with the engine running. If the brake pedal feels hard (no power assist), install a new valve and then repeat the test. If the brake pedal still feels hard, install a new brake booster. If the brake pedal movement feels spongy, bleed the brake system. 2018 SE SDV8 4.4 Byron Blue |
Good find... |
I would do the same |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Mine does exactly the same and its always done it (well for the last 6 years) Geoff |
Thanks Kot!
