Home > Technical (L405) > Hard brake pedal
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Hard brake pedal
New to me 2016 4.4 has a hard brake pedal first thing in the morning, starts and drives normally, brake pedal is then what I would call normal for the rest of the day when starting
Is this normal or a sign of things to come? 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #718906 31st May 2025 8:31pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
If it has an auxiliary battery in the right side of the trunk, under the panel, check if it is OK, mine did this when the aux batt was gone...
Post #718926 1st Jun 2025 11:12am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Could there be a vacuum leak affecting the brake booster?
When I changed my plugs I disconnected the vacuum lines and when I went to re-start the car after the service the brake pedal was hard until I started the engine. Formerly happymadison1978
Post #718931 1st Jun 2025 11:49am
Andyyav
Excellent tip Adara, I did have the ‘gearbox fault HDC not available ‘ flash up randomly a few days ago, I believe these are signs of a failing battery, the aux battery has a date stamp of 2016 so could be on the way out, my battery tester says it’s ok but I’ll monitor it, the main battery however has a date stamp of 2020 and is only showing half charge Thumbs Up
Stephen 125 I’ll check the vacuum later in the week see if holds over night Thumbs Up 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #718963 1st Jun 2025 9:55pm
Stephen.125
I'm sure you'll sort it! best of luck. Thumbs Up Formerly happymadison1978
Post #718966 1st Jun 2025 10:28pm
Mine does the same, has done since I've owned it...
No faults at all showing on IID
Changed all four callipers, all discs and pads and bled through the entire system (not to try to fix this issue thought) and it's still the same... Oh, and both batteries are new....
Sure it's been talked about before and some do it and some don't...!! Thumbs Up Pete
Post #718998 2nd Jun 2025 10:44am
you need to put your foot on the brake pedal to start hence its in the position its in ...so its normal.. ... - .- -.
Post #719006 2nd Jun 2025 11:25am
Kot
Thumbs Up +1 from WS manual
BRAKE BOOSTER
COMPONENT TESTS
1. Check all hoses and connections. All unused vacuum connectors should be capped. Hoses and their
connections should be correctly secured and in good condition with no holes and no collapsed areas.
2.Inspect the valve on the brake booster for damage
3. Check the hydraulic brake system for leaks or low fluid
With the automatic transmission in PARK, stop the engine and apply the park brake. Pump the brake pedal several times to exhaust all vacuum in the system. With the engine switched off and all vacuum in the system exhausted, apply the brake pedal and hold it down. Start the engine. If the vacuum system is operating, the brake pedal will tend to move downward under constant foot pressure. If no motion is felt, the vacuum booster system is not functioning
4.Remove the vacuum hose from the brake booster. Manifold vacuum should be available at the brake booster end of the hose with the engine at idle speed and the automatic transmission in PARK. Make sure that all unused vacuum outlets are correctly capped, hose connectors are correctly secured and vacuum hoses are in good condition. When it is established that manifold vacuum is available to the brake booster, connect the vacuum hose to the brake booster and repeat Step 3. If no downward movement of the brake pedal is felt, install a new brake booster
Operate the engine for a minimum of 10 seconds at a fast idle. Stop the engine and allow the vehicle to stand
for 10 minutes. Then, apply the brake pedal with approximately 89 N (20lb) of force. The pedal feel (brake
application) should be the same as that noted with the engine running. If the brake pedal feels hard (no power
assist), install a new valve and then repeat the test. If the brake pedal still feels hard, install a new brake
booster. If the brake pedal movement feels spongy, bleed the brake system.
 2018 SE SDV8 4.4 Byron Blue
Post #719013 2nd Jun 2025 12:03pm
Good find... Thumbs Up
Mine only feels hard first thing in the morning, you can leave it for hours and it is "normal" when you press it....
The pedal drops as the car starts...
Maybe it needs a new booster but I think I'll wait for some other signs... or it's hard after leaving for 10mins.... Whistle Pete
Post #719044 2nd Jun 2025 6:31pm
Kot
I would do the same Thumbs Up but its probably just a very slight vacuum leak 2018 SE SDV8 4.4 Byron Blue
Post #719049 2nd Jun 2025 8:54pm
supershuttle
Mine does exactly the same and its always done it (well for the last 6 years) Geoff
Post #719051 2nd Jun 2025 9:35pm
Stephen.125
Thanks Kot!
Yeah fair points all, if you can press it you can just call the very first press of the pedal "today's cardio"
Unrelated... I've never been so unfit Rolling Eyes Very Happy
Cheers! Formerly happymadison1978
Post #719058 2nd Jun 2025 10:23pm
