Home > Technical (L405) > Autophix 7310 Code Reader - the JLR Compatible Version.
Page 1 of 3 123>
Stuart-
I fancied getting a code reader. I know the GAP IID tool is the one most people recommend, but it’s quite expensive, and there are different versions like the G2 and G4 that don’t all work with every model. It also has to be linked to a specific chassis number, and in some cases, you need to buy additional licences. With all that in mind, I decided to see what else was out there. After doing a bit of research, I picked one of these up.
They do a few different ones, but the 7310 is specifically for JLR cars.
Obviously, it doesn’t offer everything the GAP tool can. For example, it can’t calibrate deployable side steps. But it does reset clutches (though I’ve not quite got my head around that part yet). It reads and clears all fault codes, lets you do the battery reset procedure, turns off service lights, and so on. From what I’ve seen so far, it seems to cover the functions most people are likely to need. And they don't need linking to a chassis number.
Heres what it does:
Autophix 7310
  • Full system diagnostics for Jaguar and Land Rover (engine, transmission, ABS, SRS, etc.)
  • Standard OBDII functions: read/clear codes, live data, freeze frame, I/M readiness, O2 test
  • Over 130 special functions, including:
    - DPF regeneration
    - ABS bleeding
    - Oil service reset
    - Auto gearbox reset
    - Electronic parking brake reset
    - Air suspension reset
    - TPMS reset
    - Battery reset
We now have them on the site here: Autophix 7310 Range Rover Code Reader & Diagnostic Tool 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
2006 Bentley Flying Spur in silver
Post #715536 4th Apr 2025 12:47pm
detgnome
United Kingdom 2013 Range Rover Vogue SE SDV8 Carpathian Grey
Hi,
I had a look at this one as well - any more thoughts on it so far? I see the 2025 version is around £120 on Amazon, but the 2024 version is about £65-70 on Ali Express.
Post #718308 21st May 2025 5:38pm
Smp68
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
I have brought one of these to replace the reader I lost when my last range rover was stolen. The pins in the connector can bend if you are not careful. They work well but take a while to boot up. They offer more than basic readers but not as much as a gap tool.
Post #718311 21st May 2025 7:26pm
Stuart-
detgnome wrote:
Hi,
any more thoughts on it so far?.
It did what I wanted it to do, but I'd like to plug it into other cars to do different things to be on the safe side, or at least get some feedback as SMP has given before I stick my neck out and contact the manufacturer in Shenzhen to see what their MOQ is. 2017 4.4 SDV8 Autobiography in black
Post #718359 22nd May 2025 2:20pm
detgnome
Hi, quick question, would this show what is bringing up my occasional 'Service Required' message?
Post #718956 1st Jun 2025 7:49pm
Kot
Oil dilution brings on service required--change your oil
Short journeys, increased interrupted Active Regenerations of DPF contribute to fuel diluting Engine Oil.
Possible to have 3or 4 oil changes per year depending on your driving style. 2018 SE SDV8 4.4 Byron Blue
Post #718977 2nd Jun 2025 8:26am
Kot
Re: Autophix 7310 Code Reader - the JLR Compatible Version.
Unnecessary quote removed
The Autel AP200 is half the price and does the same, and is BT 2018 SE SDV8 4.4 Byron Blue
Post #718979 2nd Jun 2025 8:28am
Stuart-
It doesn’t do the same. From what I’ve just read:
The Autophix 7310 has over 130 functions and is designed specifically for all Jaguar and Land Rover models.
The Autel AP200 has just 19 service functions, and not all of them work reliably on JLR vehicles.
It’s not a like-for-like comparison. 2017 4.4 SDV8 Autobiography in black
Post #719022 2nd Jun 2025 1:08pm
Kot
Very Interesting-Can you tell me what the 119 functions are?
The AP200 does a lot more than the 19 functions try looking at the technical service tab Rolling with laughter scroll down and read.
https://www.autelstore.co.uk/wholesale/aut...anner.html
£46 for a BT machine is all I needed in the past 4 years 2018 SE SDV8 4.4 Byron Blue
Post #719031 2nd Jun 2025 3:20pm
Stuart-
I’ve looked into this a bit more and I don’t think it’s fair to say the Autel AP200 “does the same” as the Autophix 7310.
Yes, the AP200 is Bluetooth and works across multiple brands, but the number of service functions it offers depends heavily on the specific vehicle. Autel say it supports “up to 19” special functions, though some listings claim 25 or more. It seems to vary, and from what I can gather, not all of them work reliably on JLR models. You also have to pay extra to unlock other brands.
The Autophix 7310, on the other hand, is a standalone unit made specifically for Jaguar and Land Rover. It offers 130+ JLR-specific functions straight out of the box, with no apps, no subscriptions, and no messing about. It’s a different proposition.
That said, if the AP200 suits your purpose, that’s fair enough. Just not really the same tool. People have a choice. It may be that it does what most people need it to. 2017 4.4 SDV8 Autobiography in black
Post #719089 3rd Jun 2025 1:43pm
Kot
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Where did you gather that from? Rolling with laughter
I am still waiting for your reply! Can you tell me the 130 functions the 7310 does ? Whistle
Have you tried them all? or any of them? not even 1? Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #719092 3rd Jun 2025 2:57pm
Stuart-
I'm not your researcher, Kot. Google is your friend. I think you're just trolling now. It's a forum, we discuss and exchange ideas. Your style of discussion might be more suitable for Facebook. 2017 4.4 SDV8 Autobiography in black
Post #719100 3rd Jun 2025 3:58pm
Kot
You make statements yet you cant back them up? Its part of the discussion! 2018 SE SDV8 4.4 Byron Blue
Post #719103 3rd Jun 2025 5:54pm
Stuart-
You're requesting Autophix functionality information, you can download the 104-page user manual here.
On your Autotel not working on some JLR vehicles, it's documented on Disco 3 here and here.
I'm not going to research more for you. Ner Ner 2017 4.4 SDV8 Autobiography in black
Post #719149 4th Jun 2025 1:42pm
Kot
Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #719159 4th Jun 2025 6:09pm
Page 1 of 3 123>
