Home > Technical (L322) > Brake flaring tool specifications for 2012 TDV8 Westminster
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I wonder if anyone can confirm the size/type of brake flare tool required on a 2012? I suspect it's 3/16 pipework and a 4.75 DIN flare but thought best to check first.
Just discovered some brake fluid on the drive and it's coming from the steel pipe that crosses above the rear subframe to the OSR brake flexi, about six inches in from the union with the flexi. Don't know if it's just corrosion or if its taken a hit from something thown up by the tyre. I know the easy way is to cut the last few inches and join in a new piece of pipe, but it's probably best to form and fit a whole new pipe to connect under the nearside rear sill. I'll probably end-up doing all the rear pipes while I'm in there. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719198 5th Jun 2025 2:33pm
fisha
It’s standard size stuff, and it will be corroded, so better to replace it all.
Not the worst of jobs iirc. I did both rears when mine went. I made a section to go across the top of the rear subframe and then another section to run along the sill to the front wheel arch area. V8 or else ...
Post #719211 5th Jun 2025 4:31pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Here is a link to Joe90's guide to the brake lines, I did mine, a 2010 facelift a couple of months ago and it is a brilliant guide.
https://www.fullfatrr.com/forum/topic25799.html
It is a 4.75 DIN flare, make sure the new fittings you get are 4.75 DIN otherwise you will have to have another flare tool.
Here is a link to a video I made.
around time stamp 7.18 is a bit about the flare tools I used.
Will
Post #719225 5th Jun 2025 7:05pm
FFRR has DIN flares and fittings, at the time, I got away with using SAE flarings (I now have a DIN flare tool). .
Post #719226 5th Jun 2025 7:39pm
JMC
Thanks for the comments chaps!
I've got 25ft of Kunifer coming, along with a cutter, bender, flaring tool, terminations and numerous bleeding devices etc.
Was under the car yesterday and replaced the propshaft. Might as well do everything I can while all the bits and pieces are off. Getting the fuel tank cover off is a job in itself. The brake pipe is a 'one piece' from the front wheel arch all the way to the o/s/r. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719266 6th Jun 2025 9:10am
Baltic Blue
Did you take any pictures of the fuel tank cover that you can share?
Lots of L405 posts but never seen L322 cover, just wondering is it similar to and does it actually support the tank.
Thanks
Post #719269 6th Jun 2025 9:36am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I’ve just finished replacing my front to back hard lines with braided lines having done quite a bit of research on them. The advantage is that the flexibility of braided lines means that you avoid having to drop the subframe or make up any din flares.
I’ll post a full write up in the next few days with all the info. for those considering brake line replacement.
With the fuel tank cover; the trick is to drop the front down first so that the cover clears the two threaded spigots adjacent to the prop shaft and then when the cover has dropped rotate it laterally so that the front goes in toward the prop shaft and the back squeezes past the rear subframe mount.
A bit of elbow grease is required but I didn’t have to fight it !
Sam’s motor and machine just posted a useful video that includes brake line replacement here : https://youtu.be/ET8b2JXhD0o?si=VkbNMYB1JUJcrj-A TDV8 4.4 2012
Post #719273 6th Jun 2025 9:59am
There are some pictures, in place and off the car in my brake pipe guide. No it does not support the tank. .
Post #719313 6th Jun 2025 2:53pm
JMC
Took a couple of photos for you Mike. Gave it all a wash first - not just for aesthetic purposes - it was to avoid filling my eye sockets with dust and crap when it comes to re-installing them! The cover is what it says - a cover! The tank has a separate securing strap and the cover doesn't support the tank in any way.
Post #719376 7th Jun 2025 3:12pm
Baltic Blue
Thanks for pictures
Best wishes with your project Thumbs Up
I replaced all the brake pipes on my Classic 30years ago with Cunifer., don’t think it’s still on the road, but the pipes will still be fine Rolling with laughter
Post #719382 7th Jun 2025 8:40pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
What length braided hoses did you buy please. Thanks
Post #719387 7th Jun 2025 10:20pm
