On again, further to the turbo fault that’s now been tested and turbos all ok. Took it for a run amd it came up with P004B fault Turbo boost control solenoid B. Someone has put me in the direction of the valve on the front cross member. Tested it with a vacuum tester and it wasn’t moving took it off and bench tested with the vacuum tester straight onto the actuator and it moved. There is also the other solenoid on the valve getting a resistance reading on that. With the fault code is it usually the vacuum side or the solenoid?
