![]() | Home > Technical (L322) > Differentials and transfer box oil change |
MC-RR Member Since: 26 Jan 2022 Location: Monte Carlo Posts: 30 ![]() ![]() ![]() |
I doubt mine was ever changed at 110,000miles. It was still in good condition when i changed it and i suppose it also depends how the car is used. I do plan to do it every couple of years however. Not too difficult to do. RR HSE TDV8 4.4 2012
TomP Member Since: 06 Jan 2021 Location: Surrey Posts: 10 ![]() ![]() ![]() |
Thanks, Martin. Our L322s are ageing and deserve some TLC. The bi-annual oil changes seems sensible husbandry and, as you say, not that difficult to accomplish. |
timl322 Member Since: 05 Apr 2024 Location: Minehead Posts: 9 ![]() ![]() ![]() |
Great writeup - about to do mine. When you say the drain plug on the rear diff needs a 3/8” socket, do you mean square or hex? Is it def 3/8” and not 8mm as they are different? Thanks, Tim |
Hi Tim,
Thanks Martin - I’m sure I will! I take it you mean a 1/2” to 3/8” converter? |
Scratch that - I’ve just realised what you mean. Good plan! 👍 |
That would work perfectly |
