Home > Maintenance & Mods (L322) > Tapping noise 5.0 sc 2011
Limey
United States 2011 Range Rover Supercharged 5.0 SC V8 Fuji White
Yes, I have researched all the threads, I love my 2011 L322 5.0sc but the noise is eating me from the inside.. 112k miles.The noise is noticeable at idle/ going through a drive thru.
So far I have replaced..
Timing chain guides and all ancillary equipment.
Supercharger coupler.
High pressure fuel pumps and lifters.
It definitely isn’t a/c related.
How loud would a bad injector be? I can’t find any video/sound clips.The motor is strong and pulls hard no codes. Any of my esteemed fellow owners have any unique experience in this? I greatly appreciate your input.
Post #719756 14th Jun 2025 3:46pm
You said....
Probably a silly question but did you change the chain...??
Faulty injectors can be pretty noisy....
Needs some diagnostics with a decent tool.... Thumbs Up Pete
-Click here for Thread-
Post #719757 14th Jun 2025 3:59pm
Limey
Thanks for the quick reply, the chains were replaced too. I’m at my wits end!
Post #719758 14th Jun 2025 4:06pm
A good diagnostics and you should be able to tell if the injectors are poorly using live values...
You need a mechanic who knows his way around the engine...
Land Rover or Jaguar will do, the engine is a Ford unit.... Thumbs Up Pete
Post #719760 14th Jun 2025 4:28pm
Limey
I’ll get on it Monday BTW what does a noisy one sound like? I can’t find any video/audio. Thanks Martin
Post #719767 14th Jun 2025 6:32pm
Limey
Here is the link to the video.
https://youtube.com/shorts/R6pRMUyaFQE?si=43nAaMhGlYGD8gCI
The area of the most tapping is on the underside of car ( driver’s side )
Post #723453 26th Aug 2025 1:29am
Fiiz
Malaysia 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
Did you make sure to tension the chain /remove slack on the non-tensioned side before tightening cam bolts?
It really does sound like a loose end timing chain (which coincidentally is on the bottom area near the crankshaft pulley)
Post #723506 27th Aug 2025 7:23am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
As Fiiz said, that sounds like tensioners are not doing their job properly, I have my 5.0 rebuilt and there was a problem with some tensioners, i would double check as that still sounds like you have chain slaps etc
Post #723515 27th Aug 2025 10:16am
Limey
Thanks for the input. Any way of checking besides having it done over again? There are no codes being thrown, car runs like a champ. Maybe the cure is to keep windows up and not go through any drive thru establishments…
Post #723554 27th Aug 2025 11:14pm
Limey
The chains tensioners etc were done at the dealership. I doubt it it was a case of a misguided install. My Indy says live with the noise, it’s nothing to worry about, but that doesn’t work for me. Just trying to find peace…
Post #723574 28th Aug 2025 6:08pm
