![]() | Home > Maintenance & Mods (L322) > Tapping noise 5.0 sc 2011 |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
You said....
| Limey Member Since: 03 Feb 2024 Location: California Posts: 8
Thanks for the quick reply, the chains were replaced too. I’m at my wits end! |
A good diagnostics and you should be able to tell if the injectors are poorly using live values...
I’ll get on it Monday BTW what does a noisy one sound like? I can’t find any video/audio. Thanks Martin |
Here is the link to the video.
| Fiiz Member Since: 13 Aug 2025 Location: Sarawak Posts: 5
Did you make sure to tension the chain /remove slack on the non-tensioned side before tightening cam bolts?
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1526
As Fiiz said, that sounds like tensioners are not doing their job properly, I have my 5.0 rebuilt and there was a problem with some tensioners, i would double check as that still sounds like you have chain slaps etc |
Thanks for the input. Any way of checking besides having it done over again? There are no codes being thrown, car runs like a champ. Maybe the cure is to keep windows up and not go through any drive thru establishments… |
The chains tensioners etc were done at the dealership. I doubt it it was a case of a misguided install. My Indy says live with the noise, it’s nothing to worry about, but that doesn’t work for me. Just trying to find peace… |
| All times are GMT |
