Home > Technical (L322) > Rattling noise engine bay l322 5.0 supercharged
Siebengebirge
Germany 2008 Range Rover Vogue TDV8 Java Black
Hey guys,
Another day another problem with my Diva. I don’t intend to say what I think the problem is because I don’t wanna influence your opinion on the noise.
https://youtu.be/9xYffZfDPgs?si=5IcwPEN8SEN6VG3z
What do you think could be the culprit? The noise is coming from somewhere of the right upper engine compartment (right upper timing chain cover).
Thank you very much in advance and have a good eve.
Best,
Vincent
Post #719817 15th Jun 2025 8:57pm
fisha
To me ( and I am no expert ), but that sounds like a chain running against something. V8 or else ...
Post #719836 15th Jun 2025 11:31pm
Ewwwww, now that don't sound good sir... Does sound like a guide has moved or worn maybe? Crying or Very sad
Post #719841 16th Jun 2025 1:21am
Siebengebirge
Hi guys, thanks for your replies. Could it as well be a lengthened chain or maybe a broken VVT?
Post #719893 16th Jun 2025 10:12pm
dhallworth
That doesn't sound right at all Sad
It's not a noise that I recognise or can make out from a recording though I'm afraid.
Post #719898 16th Jun 2025 11:36pm
Siebengebirge
Hi guys,
Just had a look at the car again and I am wondering if the play in the chain is normal when engine not running hence no oil pressure. Please see attached video.
https://youtu.be/qcxRPD2x0Gs?si=SYXOKipmPg6rwCdc
The previous owner said he changed guides, tensioners and chains. But at the moment I think he only has changed the tensioners and guides. They‘re from Apex which anyway isn‘t good.
Thanks for your opinion!
Best,
Vincent
Post #719912 17th Jun 2025 10:06am
dhallworth
That looks waaaaay to slack in my opinion.
Personally, with that much slack in the chain I’d not be starting the car again in case it skips teeth as if it skips enough teeth it’ll bend valves.
Post #719913 17th Jun 2025 10:39am
I completely agree with David… That don’t look right to me at all. On another note, why on earth would he not have changed the chains if he’d changed the guides & tensioner? Seams abit fishy to me… 🤔
Post #719919 17th Jun 2025 12:13pm
Siebengebirge
I guess he only has changed the tensioners and guides because for the chains you need to undo the supercharger and valve covers…
Post #719922 17th Jun 2025 12:20pm
Never tried doing half a job on them but I guess that makes sense? Albeit goes against everything I stand for only doing (well less than half a job!) 🙄🙄🙄
Post #719926 17th Jun 2025 12:35pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
My chains sound noisier than yours but with half the amount of play in the chain, but I would defiantly say that is way too much slack and need doing asap.
The noise to me though sounds like a dry screech, ie, dry bearings maybe on belt tensioners. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720943 6th Jul 2025 7:55pm
