|  | Home > Technical (L322) > Second battery died after 1 year - battery or something else |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | I would hazard a guess that Walmart batteries are built to a price...  | ||
|  17th Jun 2025 8:20am |
| invisible999 Member Since: 13 Jan 2024 Location: Reno, NV Posts: 58      | Well, the price of battery was $190. The new AGM one they put is $210. Local dealer happily will offer you battery for $600. That most likely was made by elves in moonlight and blessed with milk of unicorns...
|  17th Jun 2025 4:29pm |
| davidrosenbloom Member Since: 02 May 2025 Location: USA Posts: 20    | So I my experience is that if you dont lock the car and say if you leave the keys in, the car never fully goes to sleep; if you lock it and put the keys a full thirty feet away you shouldnt have an issue; I ran a trickle charger to the battery and a negative or ground spot a foot away from the battery so I can check the voltage with two alligators and a voltage meter at the front grill; you should get a reading - should be around 12.6 w a new battery and then lock it as abvove and then check every 12-24 hours; if you are losing say more than a .10v per two days you have either a car thats not shutting down or you have a parasitic drain from say an amp or radio thats not dshutting down; for this - if you suspect thids; close the hood switch to let the car think its all buttoned up lock it and then put the keys far away; then go through each fuse with a voltage meter and see if you have juice to one of them - note bene you MUST wait at least 20 - 30 m after shut down to ensure that the car is "sleeping."
|  4th Jul 2025 3:30am |
| Posting Rules
