Home > Maintenance & Mods (L405) > L405 Battery Change
Eddthedoc
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Indus Silver
L405 Battery Change
Hi all. Apologies if this has been covered but the search function has not helped me find me an answer.
I have successfully changed my 2019 L405 P525 battery uneventfully and all is working well.
As I own a GAP IId tool I plugged it in to do the battery reset but the battery does not come up under the BCM menu - just the message ‘enable protected functions’.
I’ve not been brave enough run that routine as I suspect this is the LR security update doing this, but I may be wrong.
My questions are:
1. Shall I just forget all of this battery update thing and get on with my life?
2. Should I just “enable protected functions”
3. Anything else?
TIA
Post #719985 18th Jun 2025 5:47pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Enable protected functions is a bcm setting that if for say you have a short on a vanity mirror supply, the bcm shuts the power off to that circuit as it is unfused, enable protected functions would re-enable the output assuming the fault was cured. You only need to run this if you have a dtc stating that a protected function has been disabled.
On the 2016MY Battery reset is found under BCM, but not sure on 2019, are you using a gen 4 IID? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719988 18th Jun 2025 7:08pm
Eddthedoc
Thank you so much for the clarification this is a Gen3 iid tool.
I will contact the company too
Post #719989 18th Jun 2025 7:11pm
What version of firmware do you have on your Gap tool? It might need an update. I didn’t have a few features on mine until I did an update and as if by magic, they all appeared Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #720002 18th Jun 2025 11:19pm
Eddthedoc
Solved!
The device was running the right firmware but the battery reset function is in a different menu to The BCM as was in the manual.
It’s in the “GWM Gateway Module” for my 2019 V8 SC AB
With thanks for your help and Patrick From GAP Diagnostics for a quick reply
Post #720039 19th Jun 2025 11:04pm
Glad you got it sorted.
Another example of the fantastic support from Patrick Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #720069 20th Jun 2025 11:28am
