![]() | Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
How is the cover removed please? I need to disconnect the capacitor in my MY21 until I own a Gap tool that will do the CCF change. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35870 ![]() ![]() |
pull from the top left and work your way along the top... ... - .- -.
Thanks Stan. I had started in that area but chickened-out. I'll have another attempt tomorrow. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
My 2014 L405 SDV8 came from the factory with no stop start, (thankfully) not even the switch. I have a large auxiliary battery.
As Stan says, but you have to pull so hard that you think you will break it, I use the vent in the recessed bit as you can get your fingers thought the slots to get a good grip, then a sharp, violent yank straight out towards the other side of the boot....... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Thanks Pete, noted. |
Mine probably doesn't have a capacitor as it has a 48V battery, but hopefully I'll find something to disconnect. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
I disconnected the auxiliary battery and the heated steering wheel and seats stopped working |
I've removed cargo area fuse 34 MHEV 5A. There's now a red triangle in the top right of the instrument display directly below when the stop/start icon shows but it seems that stop-start is disabled. If that's all the repercussions then it can stay that way until I decide to get a G4 IIDtool.
I tried this CCF change on my MY21.5. Whilst I forgot to set start-stop off prior to uploading the change, the change has no effect. However the IIDtool gets stuck right near the end of upload processing (DADC learning CCF), requiring the app to be killed, the tool removed and the battery to be disconnected to regain OBD access so perhaps the CCF isn't properly loaded for some modules. The change is showing as having been successful upon re-reading the CCF after the battery is reconnected. I'm advising Gap of the behaviour. L405 D350 SE Carpathian Grey D5 19" rims |
Patrick at Gap has advised that the tool incorrectly attempts to cause a non-existent module for this car to get a fresh copy of the CCF, hence the perpetual wait. Also advised is that sometimes the stop-start change can take some time to take effect, so fingers are crossed that the change will eventually work. L405 D350 SE Carpathian Grey D5 19" rims |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721 ![]() ![]() ![]() |
Mine was exactly like that too, frozen at the last step. For the rest of that day the stop start was disabled, however the next day it was back on . Not sure whether user error , will try again today . 2019 SV AB Dynamic Scafel Grey |
The tool's latest s/w version incorrectly sends a message to the named module then waits for a response, but as the module doesn't exist on the L405, the app waits forever unless forced closed. The s/w will be changed to not attempt to contact this particular module on a L405.
Mine has started logging the following 2 DTCs since I started changing the CCF. I don't know if the displays are objecting to the start-stop change, another CCF change, simply because the CCF was updated or due to an unrelated issue. The faults will clear but return on the next start-up. Sometimes the code is 2B on both.
