![]() | Home > Technical (L322) > 4.4 tdv8 Westminster reduced performance |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3874 ![]() ![]() ![]() |
Does the car bring up the Restricted Performance alarm at any specific engine revs, notably 2500 rpm ?.
Joff1961 Member Since: 24 Dec 2023 Location: Wroughton Posts: 18 ![]() ![]() |
Yes about 2,500 revs and goes away when you turn the engine off
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 52 ![]() ![]() ![]() |
Have you done an oil change recently 2012 Westminster 4.4 tdv8 |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 200 ![]() ![]() ![]() |
I have had the same issue and also the issue with a sticky CSOV.
I do an oil change every 5K, this all started when I did the oil cooler so had the donut off and all was fine then had it off again to check for any leaks but had none but do have a very small weep from the new fuel filter I put on. I must of moved something but can’t find anything. Will just have to keep checking until I find it. |
Reason I asked about oil change is I had the same kinda of issue mine turned out to be the oil drain leaf spring in the bottom of the oil filter housing hand come loose and oil was permanently draing out of the oil filter houseing 2012 Westminster 4.4 tdv8 |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
I had this after getting the oil cooler done but my problem was that the two pipes at the front of the engine had slipped off. If you’ve already replaced one of them, it’s unlikely to be the same problem for you. |
Ok I think I have found my leak, not vacuum but pipe that comes off the turbo cross over pipe and goes to left side of engine and bolts on
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 411 ![]() ![]() ![]() |
Any use?
I can feel it coming out the joint by the clamp, I ordered the joint for the other end with the two bolts on it LR022775 but can’t find a number if it has a joint/seal on the clamp end. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8771 ![]() ![]() ![]() |
Have a look on the web link posted above, it’s the JLR parts catalogue for the 322. Pretty easy to use and all pictures.. |
Thanks for the reply, I have now found the part number which is LR022840, Maltings have them in stock |
Now fitted new part and no gas leaks, but when I took it out for a test drive I’m still getting the same code. So I think I will take the vacuum are off the actuator and do a vacuum test on that and see what happens also do a few push tests on it to see if it stick at any point. That’s the cheep part of the job |
