![]() | Home > Maintenance & Mods (L322) > Suspension fault and blowing every 10 seconds |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
iid seems to permanently show 100% open for the exhaust valve - the other body’s and solenoids etc say 0% Current stable:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Check height sensor readings for an anomaly? |
Be been driving with that screen up permanently to check it doesn’t suddenly drop - all looks above board Current stable:
Check them with iid tool or similar, what shows on screen may not be a true picture of the state of things, can't think of anything else tbh
Awesome did you change them all? Glad it was the same fault Current stable:
Just stripped and cleaned them , all seals looked good ,no dirt or grime evident, but its done the job.
Awesome….
A small update… I was convinced that the puff of exhaust would happen from the exhaust or straight from the main pipe feeding to the compressor so I disconnected it… I was wrong… air came out fast for about 3 seconds along with a lot of water droplets… i then took the exhaust solenoid out and it was wet… I check the drier it was bone dry. So i then left the solenoid out and started it a few times to let it blow the wet water out. Then I put it back together and it’s all good now 😃… I am a realist though something is causing moisture in the air to the system and it’s not in the compressor and this will likely happen again until resolved. Any ideas? Current stable:
Just to close this off I ran a full discharge of air through iid tool and reinfected and drove 200 miles yesterday… so far so good. Got a water trap to put inline too Current stable:
