Home > Maintenance & Mods (L405) > Sv 2018 seat module
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Sv 2018 seat module
Anyone with Topix have details on the removal of the driver seat?
I need to get at the seat module out for exchange?
Post #720102 20th Jun 2025 5:28pm
zenman63
Well fitted a new seat module, easy enough job with just 4 bolts and lean the seat back enough.
Now the problem with fault codes has gone but unit need calibrating.
Looks like a dealer job?
Post #720456 27th Jun 2025 6:02pm
Kot
Will this help?
https://www.diagnostic-associates.co.uk/do...ration.pdf
Edit-- just seen this in wsm
INITIALIZATION
When a replacement of the or DSM PSM is installed, it should be calibrated using the JLR approved diagnostic equipment. 2018 SE SDV8 4.4 Byron Blue
Post #720459 27th Jun 2025 6:41pm
zenman63
Thanks for that, dealer level diagnostics, nothing easy anymore.
I will let you know how it goes.
Post #720476 28th Jun 2025 9:50am
zenman63
Well managed to get the module coded and it’s not fixed the problem so need help, Topix would help or a tec at Lear that can change the frame, it’s so complicated and buried in the seat.
Warranty doesn’t want to know.
Post #720644 1st Jul 2025 6:58pm
What is the problem your trying to rectify sir?
Post #720666 2nd Jul 2025 1:26am
zenman63
The massage seat doesn’t work and the seat frame with the motor and valve needs changing.
So it’s seat out and strip and re build.
Post #720668 2nd Jul 2025 7:10am
