![]() | Home > Maintenance & Mods (L405) > Sv 2018 seat module |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 217 ![]() ![]() ![]() |
Well fitted a new seat module, easy enough job with just 4 bolts and lean the seat back enough.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1406 ![]() ![]() |
Will this help?
Thanks for that, dealer level diagnostics, nothing easy anymore.
Well managed to get the module coded and it’s not fixed the problem so need help, Topix would help or a tec at Lear that can change the frame, it’s so complicated and buried in the seat.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16380 ![]() ![]() ![]() |
What is the problem your trying to rectify sir? |
The massage seat doesn’t work and the seat frame with the motor and valve needs changing.
Weekend job to change the massage unit, just picked it up, over £600!
Well seat came out easy enough with two people and it came in the house for strip down, couldn’t get the head rest out so gave up there and it’s not a problem.
All back together and working properly,
