![]() | Home > Maintenance & Mods (L322) > L322 TDV8 4.4 Rattle from front N/S |
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 77 ![]() ![]() ![]() |
Try searching for upper control arm. There's quite a few posts you may find your noise described. The photos will show what a worn bushing looks like.
tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29 ![]() ![]() |
Thanks Jagmen, I am on it! |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 847 ![]() ![]() |
https://www.advancedfactors.co.uk/front-br...9999-176-c
Thanks Rambles. Just found a guy on YouTube who replaced this part and it certainly looks a very likely candidate for the rattle I am experiencing. Will give it a go. |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 62 ![]() ![]() ![]() |
When I replaced one of mine I saw cut it and before fitting drilled suitable holes to then secure the two halves together using pop rivets with a piece of steel strip after fitting.
Thanks Steve, did that mean you were able to fit the plate without removing the hub? |
Correct. I found the YouTube video for you:
I have gone for the same solution as Steve….use some washers !
Got it done yesterday, so thanks for the help. Took me a bit longer than I expected, albeit an hour of that was going shopping for a breaker bar to get the caliper bolts loose! The rattle has gone, hooray. |
