|  | Home > Maintenance & Mods (L322) > L322 TDV8 4.4 Rattle from front N/S |
| FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 77      | Try searching for upper control arm. There's quite a few posts you may find your noise described. The photos will show what a worn bushing looks like.
|  30th Jun 2025 2:02pm |
| tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29    | Thanks Jagmen, I am on it! | ||
|  30th Jun 2025 2:27pm |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851    | https://www.advancedfactors.co.uk/front-br...9999-176-c
|  30th Jun 2025 6:46pm |
| tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29    | Thanks Rambles. Just found a guy on YouTube who replaced this part and it certainly looks a very likely candidate for the rattle I am experiencing. Will give it a go. | ||
|  30th Jun 2025 9:32pm |
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 65      | When I replaced one of mine I saw cut it and before fitting drilled suitable holes to then secure the two halves together using pop rivets with a piece of steel strip after fitting.
|  1st Jul 2025 5:42am |
| tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29    | Thanks Steve, did that mean you were able to fit the plate without removing the hub? | ||
|  1st Jul 2025 1:11pm |
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 65      | Correct. I found the YouTube video for you:
|  1st Jul 2025 2:33pm |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851    | I have gone for the same solution as Steve….use some washers !
|  2nd Jul 2025 8:09am |
| tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29    | Got it done yesterday, so thanks for the help. Took me a bit longer than I expected, albeit an hour of that was going shopping for a breaker bar to get the caliper bolts loose! The rattle has gone, hooray. | ||
|  4th Jul 2025 3:18pm |
| Posting Rules
