Home > Maintenance & Mods (L405) > Sunroof Drains
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Sunroof Drains
After reading the horror stories about rusty drains leading to water ingress and control unit failures, I thought I should check mine…
It’s obvious that someone has been here before - note the big blob of silicon holding the front of the trim!! Where I expected the drain to be, looks like it’s been blocked off.
The car has always been looked after by the main dealer, so presumably this was their solution…?
Does anyone know the part number for the clip that should hold the front of the trim down?
Post #720706 2nd Jul 2025 5:54pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Maybe one for the L405 folk ?
Post #720707 2nd Jul 2025 6:11pm
sullivj
Apologies - I’m new here!
Can admin move it for me please?
Post #720708 2nd Jul 2025 6:32pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening Sullivj,
I would say be very careful, if the drain points are blocked up, then when it rains heavy, the gullies will get full, it will fill up, and who knows where water will go!
Depending on how you park, either level or on a gradient, I think that may push water in places you don't want it too.
And beware, when you either stop or pull away you will leave a trail of water either down the back of the car or if your window is open all over the interior and you.
I would say best to investigate before winter and get the drain points working, now you know where they are they are easy to keep clean and free, there are many threads on it on here so worth a look, and the fix is pretty easy.
DrF
Post #720717 2nd Jul 2025 10:44pm
sullivj
Thanks DRF.
I took a look earlier and both are blocked. Water was pooling in the tray. So I know I need to fix it.
I’ll report back when I have done.
Post #720723 2nd Jul 2025 11:25pm
dpm
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Checked mine last weekend after seeing the horror stories that blocked and rusted drains can cause luckily mine were clear. Got a syringe and a bit of small bore pipe and pumped a load of water down the drains to make sure all clear. Only need to take the black inner roof trim off to expose the drains fully.
Post #720820 4th Jul 2025 4:01pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
These are not the drains, and that’s not the trim that you need to remove. You have lifted the trim that hides the fastenings for roof rails. The next piece of trim nearest to the sunroof is what you need to remove to expose the drains.
Post #720823 4th Jul 2025 4:29pm
DrF
Good spot, yes it's the next bit of trim, if you open the roof you should see them.
Post #720832 4th Jul 2025 10:37pm
caymanblack
Yes I made that mistake on mine and it broke two clips. overfinch modified
Post #720861 5th Jul 2025 11:12am
