![]() | Home > Technical (L322) > L322 M62 V8 4.4 startup rattle |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 615 ![]() ![]() ![]() |
That is good news |
I'm glad you've been able to get things sorted for the most part at least. I do have a slight weep from the cam cover gaskets myself but I'll be dealing with thay on my own time and terms. Since I had the water pump replaced properly, I hardly open the bonnet any more. It's getting dusty in there, last time I checked, filling the washer bottle. |
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 23 ![]() ![]() ![]() |
Well that was a little short lived. After about 10 days of perfect starts, the start up rattle is back similar to how it was before the filter element change. I have lifted the filter element out again and re-fitted it into the bowl before fitting the cap and it has stopped the rattle again for now. I'm guessing my anti drain valve poppet it worn and moves around a little but I haven't removed it to check yet. I am totally convinced that this is my main cause of the start up rattle as I was already sure it was caused by initial oil starvation so I am happy to replace the filter housing if I can find a new one. But I would just like to be sure that no one on here has ever managed to track down a replacement anti drain valve plastic poppet or even have one made? A good 3D printer boffin could make good money if they could come up with a program or just make and sell them. Fingers crossed for your comments and information. |
I'm just keeping this going while I figure out what is happening so hope it helps someone. I was very lucky to find a BMW part number oil filter housing assembly new, old stock on ebay for £75 delivered! It is part number 11427510716 and I wasn't sure if it was identical to the Range Rover part so I googled it and got all sorts of conflicting information that completely confused me.
Well, the story continues......
OK, I'm hoping this will be my last post on this subject. After clamping the drain hose with a brake pipe clamp 10 days ago, I had no further occurrence of the start up rattle other than a very slight split second rumble on one occasion. So I think that I have found the cause of my start up rattle and this is an easy way to eliminate the maintenance drain valve leakage in the remote filter.
