Home > Technical (L322) > L322 M62 V8 4.4 startup rattle
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
That is good news Thumbs Up You will probably still be getting the occasional rattle, especially in warm weather but it will surely be less pronounced and much shorter. The filter definitely helps for the most part. What also helps a lot, as odd as it may sound, is keeping oil leakages in check.
Post #720879 5th Jul 2025 4:13pm
andyrosehome
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Cairns Blue
Yes, interestingly, I did have quite a leak from bank 1 cam cover after the chain guide marathon despite it being a new gasket and torqued correctly. Some 10mm Stainless washers on the cap nuts cured that leak but not the rattle, but it is pretty dry now bar a very small weep where the cam cover gaskets meet the timing chain cover gaskets on each bank but it is barely a weep. And having replaced the thermostat for an 89 degree stat last year, and subsequently fixing all of my coolant leaks, it is quite a joy to lift the bonnet now. These beasts demand our attention but are a joy once they are right. Thanks again.
Post #720883 5th Jul 2025 4:43pm
vs322
I'm glad you've been able to get things sorted for the most part at least. I do have a slight weep from the cam cover gaskets myself but I'll be dealing with thay on my own time and terms. Since I had the water pump replaced properly, I hardly open the bonnet any more. It's getting dusty in there, last time I checked, filling the washer bottle. Razz
Post #720889 5th Jul 2025 6:48pm
andyrosehome
Well that was a little short lived. After about 10 days of perfect starts, the start up rattle is back similar to how it was before the filter element change. I have lifted the filter element out again and re-fitted it into the bowl before fitting the cap and it has stopped the rattle again for now. I'm guessing my anti drain valve poppet it worn and moves around a little but I haven't removed it to check yet. I am totally convinced that this is my main cause of the start up rattle as I was already sure it was caused by initial oil starvation so I am happy to replace the filter housing if I can find a new one. But I would just like to be sure that no one on here has ever managed to track down a replacement anti drain valve plastic poppet or even have one made? A good 3D printer boffin could make good money if they could come up with a program or just make and sell them. Fingers crossed for your comments and information.
Post #721218 13th Jul 2025 12:50pm
andyrosehome
I'm just keeping this going while I figure out what is happening so hope it helps someone. I was very lucky to find a BMW part number oil filter housing assembly new, old stock on ebay for £75 delivered! It is part number 11427510716 and I wasn't sure if it was identical to the Range Rover part so I googled it and got all sorts of conflicting information that completely confused me.
So I decided to aer on the side of caution and just replace the plastic poppet because I could physically measure and assess the old and new parts side by side and confirm they are identical. It was also just a 15 minute job to replace the poppet, less messy and no O-rings required. That being said, after having it apart, I am 99% certain they are identical so I think I could have replaced the assembly. The only difference could be the anti-drain valve spring load which I didn't test. But I took her out for a test run last night after replacing the poppet and all good. Got her nice and hot so that the oil was thinnest so that if it was draining back I was giving it the best chance to show itself. This morning the first start was perfect so I am hopeful. I did notice wear on my old plastic poppet. Some minor wear on the one leg as others have posted but also some wear on the spring spigot where the spring has created ridges by wearing the plastic away. I suspect this is more likely to cause the poppet to seat unevenly but coupled with the leg wear could easily be enough to cause the problem. My 44 years experience as an aircraft engine engineer tells me that the spring ridges on valve poppets can cause all sorts of valve mis-alignment issues so it is always nice to find a potential smoking gun. I hope the image attached helps and I will post again in a few weeks if I have fixed it, or sooner if I have not.
Post #721379 16th Jul 2025 10:12am
andyrosehome
Sorry, file didn't upload. My bad.
Post #721381 16th Jul 2025 10:15am
andyrosehome
Well, the story continues......
The start up rattle returned again yesterday after the typical 10 days after re-seating the filter. I could just replace the entire filter bowl with the new old stock assembly that I bought, but then I won't learn anything about what causes the problem. So I decided to use a brake pipe clamp to seal off the rubber drain pipe that carries the oil back to sump when the filter is removed. The theory being that the valve may seat initially after the filter is fitted, but after the 10 days or so, manages to unseat just enough to bleed oil back to sump overnight. So I will run it like this for a couple of weeks or until the rattle returns and report back. If this works then an easy fix would be to either fit a permanent blank in the pipe, as I don't feel the twice a year filter change with a full bowl warrants the hassle that the rattle brings or, fit an in line quarter turn valve so that it can be opened at filter change and closed again afterwards.
The other part of this is that, if the valve is bleeding oil to sump, you may not be getting full oil pressure delivered to the engine components. Stand by for more......
Post #721944 27th Jul 2025 2:31pm
andyrosehome
OK, I'm hoping this will be my last post on this subject. After clamping the drain hose with a brake pipe clamp 10 days ago, I had no further occurrence of the start up rattle other than a very slight split second rumble on one occasion. So I think that I have found the cause of my start up rattle and this is an easy way to eliminate the maintenance drain valve leakage in the remote filter.
So, I have now removed my old remote filter assembly complete and have swapped the new non return valve back into the new remote filter housing ready to install it in the car. While it was on the bench, I half filled the new housing with oil with the filter installed and cap fitted tight and did a leak check on the bench while the pipes were disconnected and nothing drained out of the unit from the maintenance drain valve nor the pressure feed NRV so I am pretty confident that the new housing does not leak oil back to sump. I did suck text the pressure NRV and it is not quite completely vacuum (air) tight but it is oil tight. I also suck tested the maintenance drain valve and that was air tight. So in summary, there are 2 valves that could cause oil to drain back to sump after shut down and the one is easy to eliminate with a pipe clamp. The second isn't so easy but can be tested with the filter assembly on the bench just by filling the outside of the filter with oil while it is pressed down tight on the maintenance valve and watching for oil from the pipe connection port.
So, I won't post again if the rattle does not return but feel free to ask any questions if you need to.
Post #722364 5th Aug 2025 4:36pm
QBee
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Thanks guys. I read this 36 hours before I was booked into have the oils changed in my L322 by a garage 80 miles away. I only recently bought my 2011 L322, and had carefully bought the correct lubricants to change engine oil, gearbox oil and both diffs. And a Mahle filter, with plastic caps.
So I called Rimmers on Thursday, located an LR original paper filter and picked it up on my way.
The garage I was going to is a friend who is a TVR expert, so used to P38 engines, but not the later ones. He expressed concern regarding changing the gearbox oil without checking first if it was a simple oil change, or required a RR computer to programme anything, so asked me to research it first.
Can anyone not using Chat GPT please advise me? It’s an 8 speed ZF box in a 4.4 TDV8.
Post #722584 9th Aug 2025 1:07pm
andyrosehome
Well, I can't really believe that I'm back posting yet another installment on the start up rattle/remote oil filter rattle but the rattle returned after I fitted the new filter housing with all the supplied valves and the supplied genuine BMW filter P/No. 11427510716/Hengst E202H01 with BMW logo. Big Cry
So I have re-fitted the Mann filter element that was in my old housing and is only 2 months or so old. I did all that 2 days ago and no rattle since. If I don't post again then that means the rattle has gone but my only fall back now is to fit a 10mm barbed in line shut off valve in the maintenance drain valve pipe (or just blank it permanently both ends).
Post #722680 11th Aug 2025 12:17pm
