Home > Maintenance & Mods (L405) > L405 stop start
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
L405 stop start
My 17 4.4 autobiography stop starts, stops the engine then release the brake it pauses for a few seconds then switches the vehicle of.
Diagnostic search says starter disabled cranking time to long
Anybody any ideas of cause I have just fitted a new aux battery and did the reset 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #691539 29th Apr 2024 2:49pm
i gather this didnt happen before the battery replacement...
disconnect the aux battery [just the negative] and see if this makes any difference. ... - .- -.
Post #691557 29th Apr 2024 9:01pm
Watty
This did happen before battery replacement, it caused me to check the battery and I found battery bad, hence the change 07 Vogue SE Java Black 3.6 TDV8
Post #691566 29th Apr 2024 11:39pm
Malbro
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
Worth checking your main battery as this also influences the stop start feature. The reason I know this is because my stop start never worked when I bought my car but once a new main battery was fitted it worked perfectly.
Post #691611 30th Apr 2024 4:07pm
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
Watty,
My 2018 SDV8 has the same symptoms as your car, when the start/Stop kicks in at traffic lights and then when lift off brake the car shuts down, i would have to cycle the engine start button couple of time before the engine starts and then everything works fine.
I’ve sometimes also had problem string cr in the morning…where I get message on cluster saying ‘AEB not available’
Car is under LR warranty So going in May for TCU replacement and hopefully they can sort above problems as well?!
Post #691641 1st May 2024 12:39am
Watty
that’s the exact same let me know the outcome please
thank you 07 Vogue SE Java Black 3.6 TDV8
Post #692049 7th May 2024 9:52am
Maher2023
Hi Watty,
I have got the car back today, they said they have replaced TCU under warranty and that has supposedly fixed all the issues I was having.
Only time will tell, I’ve not had chance to check everything today but the issue with Start/Stop and car everything going off…seems to have been fixed.
I tested start/stop at traffic lights on my way back and everything work fine.
But I’ll see how it goes in coming days….
Post #692267 9th May 2024 6:13pm
Watty
thank you for the info 07 Vogue SE Java Black 3.6 TDV8
Post #692281 10th May 2024 12:04am
BLT Dave
Hi Maher2023
Has the issue returned? My 2019 did this a couple of weeks ago once after being serviced (on the way home). I then had a new main battery fitted and the issue has happened again, after a particularly long auto stop. Most of the time it works fine 2019 MY SDV8 Autobiography in Velocity Blue
2018 SL63
2022 iX3
Post #720886 5th Jul 2025 5:45pm
Maher2023
Hi BLt,
Touch wood…I’ve not had the issue return since the replacement of TLC. Batteries were not replaced.
Post #720898 5th Jul 2025 10:35pm
Gremlin500
Rolling Eyes Stop Start is a total mugs game IMHO, why the hell would anyone want it?
I disabled mine, -why?
Because 90% of engine wear happens during cranking, not to mention wear & tear in the starter gear itself, why risk a failed engine for a few percent better mpg at best?
So turn it off, the next owner may thank you and it doesn’t save a significant amount of fuel anyway.
Evil or Very Mad V6 Vogue - “Less is More” - less to go wrong!
Post #720899 5th Jul 2025 10:41pm
Kot
Thumbs Up +1 2018 SE SDV8 4.4 Byron Blue
Post #720900 5th Jul 2025 11:10pm
Kot
My God BBC2 is good tonight Censored 2018 SE SDV8 4.4 Byron Blue
Post #720901 5th Jul 2025 11:11pm
BLT Dave
Impressed this week...
So I called LRA on Monday morning, within an hour a tech was on the drive and within 30 minutes he'd confirmed extended warranty coverage for a starter motor and ordered one for pickup Thursday (this morning) . Also updated the rear diff software to get rid of a 'reduced traction' warning that popped up on start at the weekend.
Came back today, fitted the starter motor in an hour and car given back, all sorted. Much better than messing about at a dealer.
Interestingly, apparently the starter motor is £500 +VAT!
Top service from LRA 2019 MY SDV8 Autobiography in Velocity Blue
2018 SL63
2022 iX3
Post #721125 10th Jul 2025 2:29pm
