Home > Technical (L322) > AC hose burst - any advice? (edited topic)
ikjos
Norway 2012 Range Rover Westminster 4.4 V8 Santorini Black
Today when I was about to take off, suddenly a big poof with a lot of steam and coolant on the road. Stopped og got road rescue to take me home.
At home I investigated and found a busted coolant hose behind the wheel well RH.
Any idea what this is and how hard is it to change?
Any ideas? ----------------
2012 - L322 Westminster
QRV @ LA2VSA / DA1AA
Post #720941 6th Jul 2025 7:23pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
It's hard to see from the photo which pipe it is that has split. But all in that area are easy to replace. Thumbs Up 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720945 6th Jul 2025 8:04pm
ikjos
One step closer.
Think it's actually the air condition hose to condenser that burst. Looking at the color it matches the R22 refrigerant (light/neon green).
Post #720947 6th Jul 2025 8:47pm
PDC
Yes that one is defiantly the AC hose. It leads from the AC rad to the compressor. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720952 6th Jul 2025 9:32pm
ikjos
Then the big question; is it worth trying to replace myself...?
Can't find much info online or in the workshop manual ----------------
Post #720953 6th Jul 2025 9:40pm
PDC
It's a doddle of a job to replace, just a bolt on either end and from memory a fixing bracket at the Bottom of the engine. But you will need to re-gas afterwards. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720955 6th Jul 2025 9:54pm
ikjos
Good. Hopefully I'm able to get that part quickly. Not the most common car in Norway. ----------------
Post #720956 6th Jul 2025 10:51pm
Kot
If there are any other hoses on that system it would be worth replacing at the same time, as 13 years on a hose, is well past its useful life. 2018 SE SDV8 4.4 Byron Blue
Post #720965 7th Jul 2025 9:03am
