![]() | Home > Technical (L322) > AC hose burst - any advice? (edited topic) |
| ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 45
Today when I was about to take off, suddenly a big poof with a lot of steam and coolant on the road. Stopped og got road rescue to take me home.
One step closer.
| PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 95
Yes that one is defiantly the AC hose. It leads from the AC rad to the compressor. 2010 RR Autobiography 5.0 SC
Then the big question; is it worth trying to replace myself...?
It's a doddle of a job to replace, just a bolt on either end and from memory a fixing bracket at the Bottom of the engine. But you will need to re-gas afterwards. 2010 RR Autobiography 5.0 SC
Good. Hopefully I'm able to get that part quickly. Not the most common car in Norway. ----------------
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1412
If there are any other hoses on that system it would be worth replacing at the same time, as 13 years on a hose, is well past its useful life. 2018 SE SDV8 4.4 Byron Blue |
