Home > Maintenance & Mods (L405) > fuse tap from the engine fuse box
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Does anyone know how to route two wires out of the fuse panel located in the engine compartment on the passenger side? I'm trying to fuse tap both a 12V+ and an ignition source from that waterproof box...
Post #721066 9th Jul 2025 12:49pm
i duck taped my cable/wire to the bulkhead behind the 'front' of the drivers door and then routed it behind the trim..
obviously you can see it when the door is open but not when closed... ... - .- -.
Post #721188 12th Jul 2025 12:49pm
GraemeS
Australia
On my L322's similar engine bay box I drilled a small hole in the bottom just inside the edge then sealed the wire once fitted. L405 D350 SE Carpathian Grey D5 19" rims
Post #721191 12th Jul 2025 1:23pm
adara
Thank you. I was considering routing the two wires through the hole where the rest of the wiring goes, but that would require removing the fuse plate. I know it’s held by two screws, but I’m hesitant — I’m not sure what I’ll find once it’s off. Also, to get access I have to remove the wipers & the lower windshield cowl...
And the cover won’t fit properly over the fuse taps because of the protrusions that extend all the way down to the fuses. They need to be cut, but I’ve been trying to preserve the factory look. I might have to compromise...
Post #721208 13th Jul 2025 8:11am
