![]() | Home > Maintenance & Mods (L405) > fuse tap from the engine fuse box |
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884
Does anyone know how to route two wires out of the fuse panel located in the engine compartment on the passenger side? I'm trying to fuse tap both a 12V+ and an ignition source from that waterproof box...
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
i duck taped my cable/wire to the bulkhead behind the 'front' of the drivers door and then routed it behind the trim..
Thank you. I was considering routing the two wires through the hole where the rest of the wiring goes, but that would require removing the fuse plate. I know it’s held by two screws, but I’m hesitant — I’m not sure what I’ll find once it’s off. Also, to get access I have to remove the wipers & the lower windshield cowl...
