![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Andrew millar Member Since: 25 Sep 2024 Location: Northern Ireland Posts: 1 ![]() ![]() ![]() |
Hi I have the same problem did you find the cause of the leak |
s1tommy Member Since: 20 Mar 2024 Location: Coventry Posts: 4 ![]() ![]() |
@Garymcduff1 did you find anything from what i mention above? any help appreciated. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8777 ![]() ![]() ![]() |
Just as an update you can now buy LR orings as a part for the leaky Union.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2757 ![]() ![]() |
At the price, I wonder who would buy one let alone 2! |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 70 ![]() ![]() ![]() |
But Graeme, you are forgetting it’s a GENUINE O Ring - worth its weight in gold 😂😂😂😂 |
Advanced factors do them at a few quid with that part number 👍🏻
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 311 ![]() ![]() |
LR wants £24.01 each so it can politely FRO. 2012 Vogue TDV8 in Aintree green over sand |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 236 ![]() ![]() ![]() |
Less than £5 for 10 on a certain auction site. Viton BS611 - 8.73mm ID x 1.78mm C/S |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
I have some oil and definitely some coolant under this hose. It is the hose on the right rear side of the plenum.
Woodsie Member Since: 01 Jan 2024 Location: Adelaide Posts: 4 ![]() ![]() ![]() |
Hi Craig,
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
am going to be attempting the EGR cooler refresh soon.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3368 ![]() ![]() ![]() |
Oil with a blue tinge ? 2012 TDV8 Vogue (L322) |
aiye, normally its indicative of coolant in the oil. Its actually a sport |
That'sa new one on me. Any 'mayonaise' on the oil filler cap? It's usualy oil in the coolant not the other way round given the pressure differential between the 2 systems. 2012 TDV8 Vogue (L322) |
