|  | Home > Maintenance & Mods (L322) > Smoke in Engine Bay NSF |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | have you recently changed the oil filter ? | ||
|  14th Jul 2025 4:41pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | I have but the problem has been occurring for a few months. I thought it might be oil leaking from the oil cooler and hitting hot pipes and producing the smoke. I've since changed the cooler but the problem persists. I've changed to the oil filter twice. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 4:44pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Ps. Ive just done a smoke test (my first time!) Via the left air filter pipe and the MAP sensor. No leaks detected....if I've done it correctly of course... 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 4:45pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | just do a quick check for me, carefully remove the oil filter, look into the bottom of the oil filter housing, and see if the the flimsy metal spring clip has moved or been dislodged, this can easily happen when doing a simple oil change | ||
|  14th Jul 2025 4:52pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Thanks. Will do and report back. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 4:53pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | The photo below shows the tiny ( about the size of a 1p piece ) , rubber valve that opens when you remove the oil filter, circled in red, if it is not seating properly when you refit the oil filter, you will have oil being drained away unecessarily
|  14th Jul 2025 5:00pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Agreed! Please see picture 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 5:14pm |
|  14th Jul 2025 5:15pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | yours looks OK, the rubber seal seems to be centred OK over the escape hole, can you see it  ( feel it sealing ) when you carefully push down on it with the end of a small screwdriver ?
|  14th Jul 2025 5:32pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Thanks. I'll check that 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 5:48pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Yes, all seems good 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  14th Jul 2025 5:59pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Quick uodate to this. Found the problem!!! It was the RH Fr downpipe. Replaced and all seems good. 2011 L322 Vogue SE 4.4 TDV8 Sumatra Black. Ivory Interior. | ||
|  22nd Sep 2025 6:21pm |
| JedY Member Since: 29 Dec 2024 Location: Burnley Posts: 22      | Quick update to this. Found the problem!!! It was the RH Fr downpipe. Replaced and all seems good, no smoke!
|  22nd Sep 2025 6:22pm |
| Posting Rules
