![]() | Home > Technical (L405) > Replacing VVT - LR177463 (superseeds LR126832) |
myL405 Member Since: 15 Jul 2025 Location: Antwerp Posts: 8 ![]() ![]() ![]() |
My 2018 L405 has most likely an issue with the Engine Variable Valve Timing (VVT), which is describe in more details here https://static.nhtsa.gov/odi/tsbs/2020/MC-10183920-0001.pdf. That's what the DTC indicated.
Thanks for your help. I've seen and read that post. There it looks indeed straight forward, but the L405 needs some more stuf to be removed (wipers, bars) before I can access it. As always, it helps if you know what and how-to avoid unnecessary steps. |
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 36 ![]() ![]() ![]() |
Removing the cowl and center bulkhead is straightforward and similar across all L405 engines. Download the service manual from the forum's Wiki link and look at the cowl removal and center bulkhead removal in the Front End Body Panels section. |
I will do so. Thanks for sharing your experience |
My attempt today was partly successful. I managed to come close the the sensor, but even in the lowest height, it was still far under the front window behind the back of the 2.0l engine. Needed a mirror to see the sensor and there were tubes in the way. Did not try to undo the visible bolt and decided to make it someones else challenge. |
