Home > Maintenance & Mods (L322) > 3.6 water pump failure
Rudyard1
I had the belts replaced about a year ago along with pulleys etc but not the water pump. Has anybody any experience of doing this themselves? Couldn’t find anything in the wiki but shirley some poor soul has had to attach theirs?! 2007 Range Rover Vogue 3.6 TDV8
Post #720750 3rd Jul 2025 1:19pm
MarianaWestminster
I've replaced a 3.6 waterpump before, if you have a look on here for the power steering pump replacement guide by member Pawl it will give you detailed steps to get down to the point of removing the auxiliary belt.
That's as far as you need to go to get at the waterpump.
From memory, it's essentially a case of partially draining the cooling system by first removing engine under tray and front undertray, accessing drain tap on the engine radiator (n/s of radiator) drain approx 2 litres of coolant or the whole lot if you prefer.
Up top remove intercooler hoses and disconnect coolant hoses being wary of the brittle plastic junction pipe coupler located n/s of car then remove top radiator plastic shroud inc disconnecting viscous fan electrical connector.
Remove viscous fan (engine fan, left hand thread!) using special spanner and pully holding tool (eBay) then release belt tensioner and slip off the auxiliary belt.
The waterpump is held on by 4 bolts (again front memory) remove but be aware more coolant will come flooding out if you didn't opt to drain most of the system down.
Also check the idler pullys and belt tensioner pully condition whilst your at it to ensure there is no play or roughness in the bearings whilst your in there.
Re assembly is reverse of the removal ensuring to correctly route the auxiliary belt (diagram in the workshop manual) and then refil and bleed the cooling system.
Hope this helps but as I say Pawls guide to doing the power steering pump is best to follow.
Post #720774 4th Jul 2025 5:08am
Rudyard1
Well this has been an invaluable help and has certainly made me realise it is actually a very easy and straight forward job - however the Britpart water pump I have is actually crap because once tightened up to the block the internals scrape the inside of the hole it sits it! It is too bloody tight a fit! Poor design and I shall now have to refit everything back to then go and order a genuine part. Lesson learnt. 2007 Range Rover Vogue 3.6 TDV8
Post #721611 20th Jul 2025 11:37am
