![]() | Home > Maintenance & Mods (L405) > Oil service |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1852 ![]() ![]() ![]() |
5W30 C1. V6 Vogue - “Less is More” - less to go wrong! |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
0W20 is correct for your vehicle.
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 256 ![]() ![]() ![]() |
Is there any benefit going 5w/30? |
5W30 is for the diesels. Kev
We use 5w/30 in our AMG Gt s and it’s fine, and in my old Gle63s so why so light oil? |
5w20 used to be specified for the 5.0 and was revised to 0w20 a few years ago. A lighter weight oil will improve cold start oil flow (but not oil pressure). Different engine designs with different requirements and clearances will have different oil requirements.
Ashley123 Member Since: 25 Aug 2025 Location: Manchester Posts: 8 ![]() ![]() ![]() |
Without sounding stupid…. What’s difference between C1 & C3 oil?
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
The additives and how much soot/ash they create. Some oil specs are designed to have low ash to reduce how quickly the particulate filter fills up etc. V8 or else ... |
Thanks for the reply!
Would any 5w30 C1 be ok or will it need to be castrol?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Any that meets the required spec will be gtg
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 105 ![]() ![]() ![]() |
I've been using Petronas 5000 FJ , which i get from Opie Oils for about £65/10 L, i get my Indy to change for new filter and my oil when the dreaded 'SERVICE REQUIRED ' comes up, so tickles to about£150 all in, i get them to plug in and give me a diagnostic reading for that too (Oil Dilution).
My car had an oil change 5k miles ago by previous owner, the service required has popped up so going to do the oil & filter change and send a sample for the oil dilution off.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
