Home > Maintenance & Mods (L405) > Oil service
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Oil service
Hi guys
Cars running fine, just over a month in on the SV now, still have this random diff sound but looking into that.
Car has full dealership history but as it’s only done 3k in 2.5 years the supplying dealer sent it locally and the changed the oil and plugs and it’s stated on the invoice trade oil and the total bill was £245 Inc plugs oil PDI inspection, yon might have seen the tyres!
So going to change the oil again so I know what’s in there.
So what are you guys using?
Recommend 0W/20 or are you using 5w/30?
Post #721619 20th Jul 2025 4:14pm
Gremlin500
5W30 C1. V6 Vogue - “Less is More” - less to go wrong!
Post #721621 20th Jul 2025 6:10pm
knwatkins
0W20 is correct for your vehicle.
STJLR 51.5122
ACEA C5 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #721629 20th Jul 2025 7:39pm
zenman63
Is there any benefit going 5w/30?
Post #721631 20th Jul 2025 7:54pm
knwatkins
5W30 is for the diesels. Kev
Post #721632 20th Jul 2025 8:30pm
zenman63
We use 5w/30 in our AMG Gt s and it’s fine, and in my old Gle63s so why so light oil?
Post #721633 20th Jul 2025 8:33pm
knwatkins
5w20 used to be specified for the 5.0 and was revised to 0w20 a few years ago. A lighter weight oil will improve cold start oil flow (but not oil pressure). Different engine designs with different requirements and clearances will have different oil requirements.
Most people will follow what the manufacturer recommends. But at the end of the day, it's your car and your choice as to what you want to put in it. Kev
Post #721634 20th Jul 2025 8:53pm
Ashley123
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Without sounding stupid…. What’s difference between C1 & C3 oil?
Thanks
Post #725525 3rd Oct 2025 8:12am
fisha
The additives and how much soot/ash they create. Some oil specs are designed to have low ash to reduce how quickly the particulate filter fills up etc. V8 or else ...
Post #725526 3rd Oct 2025 8:35am
Ashley123
Thanks for the reply!
Definitely worth going for the c1 then, don’t want to add any more problems to the dpf on the 4.4 v8 😂.
Post #725529 3rd Oct 2025 8:41am
Ashley123
Would any 5w30 C1 be ok or will it need to be castrol?
I’m doing just oil n filter change
Post #725530 3rd Oct 2025 9:42am
dingg1
Any that meets the required spec will be gtg
Forget the brand, it's just marketing
Post #725531 3rd Oct 2025 10:36am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
I've been using Petronas 5000 FJ , which i get from Opie Oils for about £65/10 L, i get my Indy to change for new filter and my oil when the dreaded 'SERVICE REQUIRED ' comes up, so tickles to about£150 all in, i get them to plug in and give me a diagnostic reading for that too (Oil Dilution).
It gets a scheduled service annually, I'm now into my own serviced schedule, as once you get to 160000M, next servive shedule will be for 192000, there is no service plan, so I guess you start from the beginning (16000) and carry on.
Post #725542 3rd Oct 2025 1:30pm
Ashley123
My car had an oil change 5k miles ago by previous owner, the service required has popped up so going to do the oil & filter change and send a sample for the oil dilution off.
I’ll get full service by indie on next service is 5k miles
Had the gearbox, transfer, 2 diff service 3k miles ago as it was 2 years over due
Post #725543 3rd Oct 2025 1:37pm
Kot
Thumbs Up very little need to sample the oil, unless you suspect other issues. For sure you will have referred oil dilution just believe the algorithm, as ignoring it will result in engine failure in the future. 2018 SE SDV8 4.4 Byron Blue
Post #725568 3rd Oct 2025 9:52pm
