Home > Maintenance & Mods (L322) > 2012 No Trailer Lights
Apache
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Evening,
Don't tow much with the RR (usually use my D4). Noticed socket badly corroded, so I replaced it and re-wired. Everything works except the rear trailer lights. 7 pin socket if that matters.
Tested at plug in the rear of the spare wheel - where connects to trailer socket and nothing.
Lights work on my D4 so not the trailer!
Tested every fuse I can find related to the trailer.
I see earlier models had a separate trailer control module - is this the case in the later models?
Struggling to find a wiring diagram for a 2012 model.
Thanks
Post #721638 20th Jul 2025 9:58pm
dhallworth
I can't help much with the wiring fault but I do know the 2012 doesn't have the same trailer ECU as the earlier cars.
Post #721645 21st Jul 2025 12:28am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Trailer lights are wired independently Ona 7 pin socket, should be brown and black to no 5 and 7 pins. If both not working does point to the wiring unit on the trailer. Easiest option is to disconnect and insulate the two wires from the socket and connect a new live feed from a rear light. If you have a multimeter check the old wires to eliminate an unlikely failure in the new socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #721655 21st Jul 2025 10:40am
