![]() | Home > Maintenance & Mods (L322) > 2012 No Trailer Lights |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349
I can't help much with the wiring fault but I do know the 2012 doesn't have the same trailer ECU as the earlier cars.
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Trailer lights are wired independently Ona 7 pin socket, should be brown and black to no 5 and 7 pins. If both not working does point to the wiring unit on the trailer. Easiest option is to disconnect and insulate the two wires from the socket and connect a new live feed from a rear light. If you have a multimeter check the old wires to eliminate an unlikely failure in the new socket. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
| All times are GMT |
