Home > Maintenance & Mods (L405) > 12v 50A anderson to rear for towing l405
RangeyRover
Australia 2017 Range Rover Vogue SE SDV8 Fuji White
Hi All,
Got a 2017 L405 with the 4.4 V8
I've burned out pin 9 for the caravan fridge in the 12 pin towing connector.
Looking to add a 12V 50A Anderson plug for the fridge and caravan charging.
Any hints for suitable exit locations at the rear? Hopefully one where I don't have to take the rear bumper off?
Thanks
RR
Post #721644 21st Jul 2025 12:06am
GraemeS
Australia
I poked a hole in the boot around the existing trailer harness with a small screw-driver from the inside then pushed the cable through, which made for an effective seal. My earth cable is bolted to the tow-bar in an existing hole on the bracket on the left side.
I have a VSR and a 50A resettable CB mounted on a piece of particle board sitting on top of the battery. If required, I can reach down through the spare wheel spokes to reset the CB. I also mounted a switch in the right side cover to switch on the VSR using its remote switch if I want power at the Anderson without the engine running.
My VSR is dual mode, switching on if the trailer side's voltage gets high enough which allows my van's solar panels to charge the car's battery. L405 D350 SE Carpathian Grey D5 19" rims
Post #721646 21st Jul 2025 1:10am
RangeyRover
Thanks Graeme, I'll have a long stare at it over the next couple of days and take some pics of the end result.
Post #721647 21st Jul 2025 1:17am
