![]() | Home > Technical (L322) > P004B and P004C 2012 4.4tdv8 |
Joff1961 Member Since: 24 Dec 2023 Location: Wroughton Posts: 18 ![]() ![]() |
So after a few hours of looking and checking looks like I have found the problem
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
good job |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 438 ![]() ![]() ![]() |
Yep, had the same problem.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 201 ![]() ![]() ![]() |
Could you help my do the same. How did you gain access to the cross over valve? Where abouts are those vacuum lines, the oily ones and the single one that had popped off?
The vacuum lines are on the right hand side if your looking from the front with bonnet up. If you look at the fan cover on that side and look down about 150mm, take the air filter box out and the first part of the hose and you can just get your hand to them. As for the value I took off the front tray under the bumper and it’s just off centre on nearside (uk car)
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather |
