Home > Technical (L405) > 303-1237 & 303-1121 DIY 3D Printed tools
nike_bytom
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Hi all TDV8/SDV8 owners,
I’m currently rebuilding an SDV8 engine, and as many of you know, special tools for a DIY person can be quite expensive for a one-off job. So while working on mine, I decided to design and make my own tools where possible.
So far, I’ve designed the 303-1121 tool to fit the front seal at the correct depth into the oil pump. This tool is simply used to tap the seal into the correct position.
For the installation sleeve, I recommend buying the Elring seal—it comes with a thin installation sleeve that works well.
The second tool, 303-1237, is for installing the CPK (crankshaft position) wheel. This is a two-part tool:
Tool A positions the ring in the correct place on the crankshaft.
Tool B fits the trigger wheel to the correct depth.
The ring position for the second tool was measured by me—46 degrees as per drawing. The measurements were taken from a working engine, and I hope this is accurate.
If anyone knows this is incorrect, please let me know and I will update the design accordingly.
Both tools were 3D printed using a Bambu Lab P1S printer with ASA material at 75% infill.
I hope this helps someone and saves you a few quid.
I’ve shared the link to my Google Drive below, where you can download all the files.
Pozdrawiam,
Rafal
https://drive.google.com/drive/folders/1lq...sp=sharing
Post #721802 24th Jul 2025 12:03pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
What an excellent use of 3D printing technology.
Thank you. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #721806 24th Jul 2025 2:59pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Fantastic! Well done 2017 (67) Vogue SE Corinthian Grey
Post #721809 24th Jul 2025 3:54pm
tomiRR
2013 Range Rover Vogue TDV6 Aleutian Silver
Very nice job!
Post #721883 25th Jul 2025 9:21pm
nike_bytom
Thanks, I wonder how long it’ll be before someone starts selling this on eBay Rolling with laughter L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #721893 26th Jul 2025 10:19am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I stumped.up for most of the gen tools direct from Bosch, but the front seal installer was a ridiculous price, so i used this and it worked great:-
https://ebay.us/m/VIBI4O L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721894 26th Jul 2025 10:38am
