Home > Wheels & Tyres > Thoughts on welded alloy wheel...!!
Well I don't know why I've never noticed before but on checking over the fatty for a trip to Spain soon I find this on the front nearside... I can only imagine the wheel has been at the right point so as not to see the weld any other time I've had it on the ramp...
Either that or they swapped my wheel for the welded one when it had the wheels refurbed some time ago but I doubt it, the place I used has been there for years and comes with excellent reviews...
Anyway I'm not happy running on it now I know it's there, just wondered what others thought, am I over reacting or not....?
Do I keep it as the spare or get another...?
Cheers Pete
-Click here for Thread-
Post #722195 2nd Aug 2025 11:14am
i've always made sure my tyres and wheels are the best condition with no tyre sidewall damage and the best condition wheels.
this weld is going to be niggling at you when your on the autoroutes going 80mph+.
i would change it Pete or try and get it into the spare somehow.. ... - .- -.
Post #722196 2nd Aug 2025 11:25am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
As per Stans reply. Change it, especially looking at the rim to tyre. You can never trust the structural integrity.
Post #722202 2nd Aug 2025 12:03pm
dingg1
As long as its a proper repair, that wouldn't worry me one iota.
Ships have thousands of miles of welded steel, not many sink
Keep things in perspective
Post #722203 2nd Aug 2025 12:19pm
Baltic Blue
I am surprised you haven’t had problems balancing it ?
Post #722205 2nd Aug 2025 12:38pm
Thanks guys, nice to have a wider view on it...
Mike, It balanced fine...
Stan, I think the same, they are four brand new Pirelli Zeros so the tyres are fine...
Dingg and Highroller, It's the structural integrity that worries me, not really the weld, what other damage did it do? with an impact severe enough to crack a forged alloy wheel I wonder what other damage or weakness is in the wheel and what would happen if it suddenly failed. Like the front uprights, it could be cracked and you can't see it....yet....
I'm thinking of getting another wheel, I just don't feel happy with it now I know it's there..... Pete
Post #722207 2nd Aug 2025 1:02pm
Gsxr1250dave
If you have any doubts then there is no doubt change it.
Post #722209 2nd Aug 2025 1:22pm
if those welded up ships went 80mph then i'll bet they would fall apart... Very Happy Thumbs Up ... - .- -.
Post #722215 2nd Aug 2025 4:02pm
D3Jon
If the rim was correctly prepped and pre-heated, then the welded repair can be very strong and nothing to worry about.
However, as you had no knowledge of the repair before now, I guess your problem is you don't know if it was carried out correctly by an experienced professional. You could always have the repair crack tested or even NDT'd for weld integrity.
But if it worries you then replace the wheel, or at least pop it onto the rear axle where the loading will be less, and implications of any failure also minimised.
Bear in mind that most cracked alloy wheels merely present themselves as a slow puncture, as the crack allows air to escape through it.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #722217 2nd Aug 2025 4:20pm
It would niggle away at the back of my mind when driving....
Post #722218 2nd Aug 2025 4:34pm
Vogue
Simple - bin it - no way would I use that wheel - they are not that expensive 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #722228 2nd Aug 2025 8:41pm
Gremlin500
How many miles have you driven on it unknowingly?
Surely it will be OK as a get-you-home spare, which might never get used?
Aluminium welding done properly is as strong as the original metal. V6 Vogue - “Less is More” - less to go wrong!
Post #722236 2nd Aug 2025 11:32pm
supershuttle
I'd agree with Gremlin, I have a weld on one of my Turbines so it's in the boot. I did drive on it for miles without noticing (it was brought to my attention by tyre fitter when I got new tyres). I did consider buying another, but a genuine 22" Turbine IS expensive. Geoff
Post #722249 3rd Aug 2025 8:35am
Baltic Blue
You wouldn’t weld a cracked front knuckle, presumably, so why is a wheel OK ?
Post #722250 3rd Aug 2025 9:24am
Kot
+1 to skip Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #722251 3rd Aug 2025 9:34am
