Home > For Sale & Wanted > [Wanted] Westfalia Swan-neck for L322
Floopy
I'm after a receiver hitch like in the picture, as my recently purchased L322 is missing it.
Edit: I've now sourced a top section and now just need the lower detachable swan neck like this.
Part no. 323039
 2006 L322 Vogue SE 4.2 S/C (no longer owned)
2008 L322 Vogue SE 4.2 S/C
Post #722201 2nd Aug 2025 11:57am
pcourtney
that is one version, but the original Westfalia swan neck tow bar that was standard OEM issue was the model below, and is on my 2011 car
the 2" receiver hitch has a downward tube connected to it, and then the swan neck connects up into that, it clicks into place using a black wheel and is lockable Smile
you can just see the 2" receiver behind the "downward tube"
and below is the downward tube adapter looking thing
Post #722219 2nd Aug 2025 5:01pm
Floopy
I've heard those style of the detachable swan-neck are not as robust as often seize in place?
How have you found yours to be? 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #722221 2nd Aug 2025 5:57pm
pcourtney
I use trailers regularly so never a problem for me, I detach the towbar when I am not towing, and clean it and store it in the cubby hole on the right hand side of the boot.
I can easily imagine people leaving it on the car for 15 years and having issues, like farmers and the like, but then they are never taking the tow bar off the car ( why would they ) , so a seized unit would not be a problem for those users Smile
Post #722222 2nd Aug 2025 6:11pm
Floopy
Very true. I need it for towing and launching the boat so summer would see regular use but winter I'd take it off. Whatever I get will receive a healthy coating on ACF50 too Very Happy 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #722223 2nd Aug 2025 6:14pm
Floopy
On your recommendation I've now sourced the top section and I'm after a lower swan-neck receiver. Smile 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #722295 4th Aug 2025 12:07pm
kevinp
Is this what you need?
Post #722300 4th Aug 2025 4:02pm
Floopy
Hi Kevin, It's the other bit I'm after; the swan neck attachment. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #722307 4th Aug 2025 5:16pm
kevinp
Well I still have the swan neck.
Me, being a numpty, decided to take it apart for greasing.
I'm absolutely Censored if I can get it back together again because certain parts have to go back in precise order for the lock to work!
You can have it to see if you can work it out. Just pay for the postage.
You might not want to take the risk though.
It was a costly maintenance error and I had to buy a new one for my own sanity.
If it ain't broke don't fix it. Doh!!!
Post #722311 4th Aug 2025 7:01pm
Floopy
If you still have all the bits I'm willing to give it a go! That's a very kind offer.
I'll ping you a PM. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #722312 4th Aug 2025 7:04pm
