![]() | Home > For Sale & Wanted > [Wanted] Westfalia Swan-neck for L322 |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1026
that is one version, but the original Westfalia swan neck tow bar that was standard OEM issue was the model below, and is on my 2011 car
| Floopy Member Since: 28 Jan 2023 Location: Devon Posts: 98
I've heard those style of the detachable swan-neck are not as robust as often seize in place?
I use trailers regularly so never a problem for me, I detach the towbar when I am not towing, and clean it and store it in the cubby hole on the right hand side of the boot.
Very true. I need it for towing and launching the boat so summer would see regular use but winter I'd take it off. Whatever I get will receive a healthy coating on ACF50 too |
On your recommendation I've now sourced the top section and I'm after a lower swan-neck receiver. 2008 L322 Vogue SE 4.2 S/C |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
Is this what you need?
Hi Kevin, It's the other bit I'm after; the swan neck attachment. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Well I still have the swan neck.
If you still have all the bits I'm willing to give it a go! That's a very kind offer.
