Home > Wheels & Tyres > Thoughts on welded alloy wheel...!!
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Would you buy a car with a welded alloy?
I might, but I would at least want a consideration on price to replace the alloy wheel.
Post #722254 3rd Aug 2025 10:22am
cass
I’ve never had a cracked or welded alloy on a Rangerover but did get a crack on a Jag wheel. Every 6 weeks or so I needed to add a bit of air when the sensor started shouting. It didn’t know it was cracked and assumed that it was just a slow puncture which I would get sorted “next week “ then it never got sorted as it never got any worse I just left it as it needed a new set of tyres shortly.
Ended up doing nearly 20K miles like that.
Only spotted the crack when it went for the new tyres, at the time a new alloy was the cost of 3 new Pirellis. I reckoned that as an unrepaired crack hadn’t got worse or failed in over a year then getting it welded wasn’t a problem so I did just that.
I don’t see a problem with having a minor crack repaired but there needs to be some common sense applied.
Post #722266 3rd Aug 2025 3:31pm
Big Boy R44ROV
Scrap it and get another.
As a coded welder a long time ago, That has had a chunk out of the casting, which will weaken it as it will have a hairline fracture in it. Some places don't repair them properly. A wheel would need pre heat and post heat before welding so as not to affect the grain structure. Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #722271 3rd Aug 2025 4:30pm
Just to put this to bed, I wasn't happy with it so got a new, old stock wheel off eBay for a very reasonable price...
Had the tyre swapped over and the ride has improved, there was a flat spot on the rim for several inches where the weld is which indicates the wheel had a good hit to do that damage and maybe wasn't OK to use...
Anyway, all sorted now, I do have to say the new Pirelli Zero's are superb.... Thumbs Up Pete
Post #722639 10th Aug 2025 3:36pm
D3Jon
Glad you got sorted with another wheel, at least you won't have any niggling feelings in the back of your mind!
Especially so, given the flat spot you mention Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #722650 10th Aug 2025 5:58pm
dingg1
Obviously not repaired properly if it still had a flat spot, good move 👍
Post #722682 11th Aug 2025 12:28pm
