![]() | Home > Technical (L460) > Pivi Pro Software Update v4.3.1 fails to update every time |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
I’d call LR Assist out |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123 ![]() ![]() |
Have you fitted an immobilizer or any other electrical thing since, my NoGo had to be switched off or it failed letters not necessarily in the right order |
Hoyboy Member Since: 21 Oct 2021 Location: London Posts: 79 ![]() ![]() |
Nope, nothing changed since the previous updates. |
Do they actually deal with things like this? Thought they’d just fob me off to a dealer |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 419 ![]() ![]() |
They will deal with these issues I’m sure but maybe good to say you’re dealer can’t look at it for weeks. Make sure you also get a LR tech out rather than a normal RAC employee who know nothing about these cars. Current fleet:
Pajo Member Since: 07 Aug 2025 Location: Byron Bay Posts: 1 ![]() ![]() |
I have had my pivi updates fail to install when my RRS p460e is parked in my garage due to weak wifi/mobile signal strength in that location. It seemed to be able to receive the update ok in that location but not install it. My solution was to park closer to the house where the signal is stronger and I then have no problem, all updates install first time every time. Might be worth checking that something is not going on with your wifi/mobile signal and trying the update where you have strongest signal. |
Slightly confused with this. Car is parked on the driveway in the exact same place it was for all the previous updates. It has never been connected to the house WiFi or used my phone signal to install the previous updates and they installed perfectly so not sure why this would be a factor now? |
tonypjr Member Since: 29 Oct 2019 Location: New Jersey Posts: 9 ![]() ![]() ![]() |
Have you tried doing a reset on the Pivi Screen. Reset all settings? |
