Home > Technical (L405) > Final electrical items to fix
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
2015 tdv6 , tailgate not functioning fully or capable of reseting and deployable towbar just bleeps
Codes are U0140-00 and U0447-00
So a BCM fault and gateway signal
There are no actual faults on the dash though
Post #722395 6th Aug 2025 11:18am
Check voltage in both batteries (if you have two)
Low voltage is the leading cause of tailgate problems... Thumbs Up Pete
Post #722416 6th Aug 2025 5:30pm
bembo449
Hmmm ? The small battery has been left go flat because previous owner didn't like stop start ! Then main one is new and charging at over 14v , so you think i should try a new small one?? Oh the tow hitch works great , i had the engine running so it didnt work
Post #722418 6th Aug 2025 5:37pm
What's the tailgate doing (or not doing) ?
Upper, lower or both ?
Post #722422 6th Aug 2025 6:19pm
I was just going to say the towbar won't operate with the engine running... Thumbs Up
Post #722446 7th Aug 2025 12:06am
bembo449
So currently the upper goes about 2/3 of the way up and stops , the lower does nothing, neither will close off the buttons , if i open fully by hand and hold button , i get 3 beeps , on occasion i can feel it resist if i pull to close
Post #722454 7th Aug 2025 7:18am
No error codes ?
When my upper tailgate wouldn't rise all the way, it was an actuator issue & needed one replacing (so I replaced both) but that logged an error code.
When my lower tailgate wouldn't close it was both a broken loom and an anti-trap sensor - https://www.fullfatrr.com/forum/topic47843.html
Post #722508 8th Aug 2025 6:49am
bembo449
posted codes at the top pal , where are the anit-trap sensors exactly ?
Post #722593 9th Aug 2025 3:30pm
If those are the only codes, then it's likely something different.
The lower anti-trap sensors are the rubber strips that run up either side of the inside of the tailgate
Post #722614 10th Aug 2025 7:03am
bembo449
So whats the way forward ? Will gap tool show exactly what's causing the issue ??
Post #722616 10th Aug 2025 8:55am
https://static.nhtsa.gov/odi/tsbs/2014/SB-10071772-6903.pdf
What are you reading the codes with now ? I'm not sure whether all readers are capable of reading all codes..... so not sure whether GAP IID would be any better or not......
Post #722617 10th Aug 2025 9:36am
bembo449
Thanks Alastair 😊
Post #722618 10th Aug 2025 9:38am
Says you are Lincolnshire, I'm 5 mins from north side of bridge and can read faults on yours with an IID if you want...??
if you do, just PM me.... Thumbs Up Pete
Post #722625 10th Aug 2025 12:42pm
