![]() | Home > Technical (L405) > Final electrical items to fix |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8821 ![]() ![]() ![]() |
Check voltage in both batteries (if you have two)
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
Hmmm ? The small battery has been left go flat because previous owner didn't like stop start ! Then main one is new and charging at over 14v , so you think i should try a new small one?? Oh the tow hitch works great , i had the engine running so it didnt work |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
What's the tailgate doing (or not doing) ?
I was just going to say the towbar won't operate with the engine running... |
So currently the upper goes about 2/3 of the way up and stops , the lower does nothing, neither will close off the buttons , if i open fully by hand and hold button , i get 3 beeps , on occasion i can feel it resist if i pull to close |
No error codes ?
posted codes at the top pal , where are the anit-trap sensors exactly ? |
If those are the only codes, then it's likely something different.
So whats the way forward ? Will gap tool show exactly what's causing the issue ?? |
https://static.nhtsa.gov/odi/tsbs/2014/SB-10071772-6903.pdf
Thanks Alastair 😊 |
Says you are Lincolnshire, I'm 5 mins from north side of bridge and can read faults on yours with an IID if you want...??
So ive had the car on iid ( thanks pete) didnt really tell me anything new , ive tested the anti trap today , continuity and live data , everything is ok
