Home > My Range Rover > rolling resto
markh1
rolling resto
There seem to be a couple of active threads about underbody restorations so thought I would post mine which is currently ongoing.
I bought my L322 back in Febraury and although not initially keen on the colour it has grown on me. I bought it because it has relatively low miles at circa 100k but has been serviced every year regardless of mileage.
Bodywork was in pretty good shape and only slight corrosion on the rear arches which I got a body shop to repair and to also repaint the rear bumper.
Underneath there was some surface corrosion on the subframes so I have stripped and repainted those but I didnt take any pictures of the process.
I could some corrosion around the jacking points so decided to investigate further.
there was a decent amount of mud in the sill covers!
I also removed the heat shields and the fuel tank guards which contained a huge amount of mud!
The jacking points werent too bad with only surface rust but there was more surface rust under the arch liners and fuel tank guards
I ground back the flakey and bubby bits mainly with a wire wheel. Compressed air line came in very handy to blow the remenants away. I then treated it with rust converter and have last night painted it with...
https://www.buzzweld.co.uk/dtm-toughliner-satin-paint.html
I had the paint tinted in something vaguely similar to the body colour but as you can see it isnt a perfect match but it will be hidden under the car or behind plastic covers. tonight I am spraying it all with Bilthamber Dynax-uc
Rust/metal gone black after rust stabaliser sprayed on
Post #722468 7th Aug 2025 12:45pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Well done that man, looking good Thumbs Up Thumbs Up
Post #722470 7th Aug 2025 12:52pm
Baltic Blue
I really like that colour, I regularly see a 2012 Vogue in Conwy where I live and it always looks good.
What’s it called ?
Post #722472 7th Aug 2025 1:18pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
That’s a cracking job 👍
What rust converter did you use?
Post #722478 7th Aug 2025 3:15pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
good job Thumbs Up Thumbs Up
Post #722479 7th Aug 2025 3:27pm
Dolphinboy
@baltic blue
it's Nara Bronze, Mike Thumbs Up
Post #722488 7th Aug 2025 5:23pm
Baltic Blue
Thanks Dolphin Thumbs Up
I really like it and seems quite rare. ( but wouldn’t swap for B.B. Rolling with laughter )
Post #722489 7th Aug 2025 5:37pm
markh1
Thanks for all the words of encouragment!
Does anyone put these foam bits back in after?
Post #722521 8th Aug 2025 11:16am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
I also like the colour, back in the 70's both Ford and Triumph made cars in Bronze and metallic brown, which are rare to see these days st shows, and usually attract the most attention.
Stick with the colour you'll be glad you did (from someone with a Red Range Rover, which are also rare to see.
Post #722535 8th Aug 2025 2:33pm
Rove Ranger
England 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
Re: rolling resto
This is my bank holiday weekend job. Shocked
Already treated the inside of the tailgate, which I'll top up again at the same time. I had a quote for the underside at a professional place who specialise in Dinitrol which was £2.5K! As much as I love the L322 that's a bit steep.
Post #722536 8th Aug 2025 3:15pm
Top job, don't forget to put loads of your favourite rust treatment through the drain holes in the tailgate, or pop the trim off and soak everything.....
I left the foam out on fatty offroader with no side effects...!!!
Funnily enough the 405 has them.... I've ditched them as well with no side effects so far... Thumbs Up Pete
-Click here for Thread-
Post #722577 9th Aug 2025 10:10am
duplicate post.... Pete
Post #722578 9th Aug 2025 10:12am
