Home > Technical (L322) > 2011 4.4TDV8 ABS/TCCM/TCM Problems
Darkpond67
Hi All,
Looking for some advice please. Long story short, I replaced the outer CV join boots, a massive struggle I have to say. After which a suspension height sensor fault, which was resolved by replacing it, also a front left ABS sensor fault which I replaced but it did not resolve the issue. During this work the battery went absolutely flat, I had not put it on charge or disconnected it, silly me!! I took it to a repair shop, they had it for three months!! During which time they diagnosed a faulty ABS module which they replaced with one I had bought on eBay. This did partially fix the ABS problem but not entirely. The other faults I have are related to the TCM and the TCCM. They were not able to fully diagnose the problems but I do not know how much time they actually spent looking at it. I also get errors related to stability control etc. I'm at a bit of a loss on how to proceed with this. If I take it to another workshop they will start from scratch and still no guarantee of it being fixed. I can get a used TCCM from eBay, TCM modules though do not appear to be available and a new one is approx. £3000!! I can get a used gearbox for £400-500. Any advice for me please, reputable repair shops maybe, mobile mechs with full JLR diags. etc. I'm in the Southampton area. Also just to say, other than the warnings on the dash the car drives fine, so there's nothing massively wrong.
Thanks in advance
Post #722471 7th Aug 2025 12:58pm
GraemeS
Australia
The fault codes are required to get some idea of the possible causes of issues. L405 D350 SE Carpathian Grey D5 19" rims
Post #722503 7th Aug 2025 9:52pm
D3Jon
Faults such as yours, after a completely flat battery might be related to the steering angle sensor losing its calibration.
With the engine running, turn the wheel from right full lock to left full lock a couple of times, do this whilst slowly moving forwards to give your tyres less of a workout.
Slim chance, but it could be as simple as that.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #722519 8th Aug 2025 10:01am
Darkpond67
Thanks both, I do have the fault codes so I'll post them and also try the steering sensor recalibration. I'll post the codes when I find them. Thanks
Post #722524 8th Aug 2025 11:28am
Darkpond67
Hi Guys,
Had to do another scan, this is the first since I got the vehicle back and this confuses me as the only work they I believe they did was to replace the ABS module but I'm not sure they actually did do that!! It seems to me that all the problems/fault codes link directly back to the ABS still, apart from maybe the TCM. I personally changed the front left wheel speed sensor, and tried three replacements, one of them being OEM!!
I tried the steering angle sensor reset but no dice!!
TCM(Transmission control module)
P2159-02 Vehicle Speed Sensor (VSS) B range/performance. Permanent
ABS(ABS control module)
DTC Description Status
C0031-25 Front left wheel speed sensor Permanent
U3002-81 Vehicle identification number Permanent
ADCM(Adaptive damping control module)
U0415-68 Invalid data received from ABS control module Permanent
PBM(Parking brake control module)
U0415-00 Invalid data received from ABS control module Permanent
TCCM(Transfer case control module)
Post #722541 8th Aug 2025 4:49pm
D3Jon
The VIN number fault on the ABS module would lead me to think it's not been coded to the vehicle?
The only thing is, I'm not sure if it has to be on the L322 - anyone else know the answer? Question
One thing I do know, is that wheel sensor locations can be mis-reported, I've had this on an early L322. In my case, the fault code said it was on the rear left, when in fact it was the rear right causing my issues.
To find out for sure, take the car for a drive and read the live values for all 4 wheel sensors. The one with an issue should show itself (EDIT ->> But you might have to drive in a circle to find out which is left vs right, as the inner wheel will go slower than the outer when turning in a circle).
Prob best to get a passenger to view the live readings, or record the trip on your diag tool and view them later, don't want any bumps! Thumbs Up
2014 Disco 4 HSE
Post #722543 8th Aug 2025 5:28pm
Darkpond67
So the ABS module was likely changed but not coded correctly??
Post #722544 8th Aug 2025 5:51pm
Darkpond67
Live values on my diag tool do show the left wheel speed sensor to be faulty but perhaps it is the RHS
Post #722545 8th Aug 2025 5:52pm
D3Jon
I don't personally know definitively, but it seems very likely according to a Google AI search:
AI Overview
Yes, the ABS module on an L322 Range Rover typically requires coding or programming after replacement. This is because the ABS module needs to be configured to work with the specific vehicle's characteristics and other control modules. Without proper coding, the new ABS module might not function correctly, leading to errors or malfunctions.
Here's a more detailed explanation:
Modern vehicles require coding:
Many modern vehicles, including the L322, need the ABS module coded or reprogrammed after replacement.
Specific configuration:
The ABS module needs to be matched to the vehicle's VIN, engine type, and other settings to ensure proper operation.
Consequences of not coding:
If the module is not coded, it might not communicate correctly with other systems, leading to errors like "ABS Inactive" or "HDC Inactive" messages.
DIY options and professional services:
While some owners opt for DIY coding using specialized software and tutorials, others prefer to have a professional service handle the coding.
Repairing vs. replacing:
Repairing the original ABS module is often an alternative to replacement, as it avoids the need for coding the new module according to Module Master.
Regards,
2014 Disco 4 HSE
Post #722547 8th Aug 2025 5:57pm
D3Jon
Drive again and go in a circle, that'll tell you which is left and right, as the ECU sees it. The inside wheels will obviously travel a shorter distance and record a slower rotational speed.
If it still turns out to be the left front, as you've already tried several speed sensors, it could the reluctor ring is broken / dirty, or it's a wiring issue with the sensor itself.
Could even be excessive wheel bearing play. Used to be a very common cause of ABS / TC faults on Disco 2's.
2014 Disco 4 HSE
Post #722548 8th Aug 2025 6:01pm
D3Jon
Re: 2011 4.4TDV8 ABS/TCCM/TCM Problems
Just remembered you said the above, you didn't get the ABS reluctor ring covered in CV grease did you? That'd likely cause a wheel speed mis-reading...
It seems doubtful, as you must be quite handy with the spanners to remove the driveshaft and do a CV boot on your own (unless you cheated and used one of the glue together ones! ) Very Happy
Just wondered if the events are somehow related?
2014 Disco 4 HSE
Post #722549 8th Aug 2025 6:10pm
GraemeS
Australia
If the comms faults regarding the ABS module are the only faults once the speed sensor fault is rectified and everything works then it is possible that the VIN mismatch is all that is wrong and can be ignored. L405 D350 SE Carpathian Grey D5 19" rims
Post #722562 8th Aug 2025 9:54pm
Darkpond67
More info, the garage it was in for 4 months replaced the ABS module with a secondhand unit but didn't copy over the VID block, hence the missing VIN fault code. Someone else has looked at it now and the only reliable way to fix is to get a new ABS module at a cost of £2300!!
Post #724186 8th Sep 2025 5:37pm
D3Jon
Check out this thread for coding the VIN to the ABS module: https://www.fullfatrr.com/forum/post611307.html
It would that a GAP IID tool can't do it (unless this function has been added?), pretty high-end kit needed to code the ABS module it'd seem...
If you still need a replacement ABS module, check out these guys, they may have one:
https://www.gentlemenofsalvage.co.uk/
2014 Disco 4 HSE
Post #724192 8th Sep 2025 7:20pm
