Home > Technical (L322) > Adjusting headlights for continental driving?
David405
United Kingdom 2013 Range Rover Vogue SE TDV6 Barolo Black
Stan,
I though on the 2013 L405 onward you still had to configure the lights for L/H or R/H driving under the High Beam Assist in the Set Up Menu. does this not change the light direction? Question 2013 405 TDV6 Vogue SE Barolo Black
2007 L322 TDV8 Vogue (Gone)
Post #546824 11th Mar 2020 6:46pm
yes you do if you have high beam assist but we with the poverty spec FF's that dont have it do no adjustments.. ... - .- -.
Post #546830 11th Mar 2020 7:01pm
David405
OK, cheers Thumbs Up 2013 405 TDV6 Vogue SE Barolo Black
Post #546832 11th Mar 2020 7:02pm
Westridge177
2011 Range Rover Vogue SE TDV8 Buckingham Blue
QuebecTango wrote:
Hi
I have a 2011 vehicle had same issue - worked it out with the aid of the beam setter at work.
Setting for driving abroad ,
O/S click lever up.
N/S click lever down
Hope this helps
When you speak of NS and OS is this when you are abroad or in uk?
Post #722573 9th Aug 2025 9:38am
Westridge177
Weegie wrote:
There is a difference depending on the model year. Up to 2009 it was down for Continent and up for UK (not sure about 2010).
It was then changed to down for UK and up for Continent.
If your adjusters are as in this photo then it us for Continent and down for UK :
Do you find that these levers act like a rocker returning to the centre after operating the shutter, or am I not doing it right?
Post #722574 9th Aug 2025 9:41am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Stan said:
both levers should be up for the UK and down for euroland.
Grok agrees !
What is clear
The WM is (well to me at least) unclear on this point and could be more clearly written so that what is clear to some becomes more clear to those that are unclear
Edit reason: first draft was written in the style of the WM and was even unclear to me as author
Post #722586 9th Aug 2025 2:02pm
Rambles
Out of interest i found this on you tube
?si=ES7cIpI_CoHLLFDe
Go to 5:30 minutes in
Clearly shows for L322, the lever down for flat beam (i.e. LHD countries like France) and up for raised beam (for RHD countries like UK)
Whilst the video shows headlight for 06-09 I don’t think there is any change for 10-12
Did i just say “clearly” ?
Haha
Post #722587 9th Aug 2025 2:26pm
