![]() | Home > Technical (L322) > lost communication with abs module won't start |
| Bricey21 Member Since: 26 May 2024 Location: Belfast Posts: 7
Did you get this resolved? I have a very similar issue with my 4.4 tdv8 and have tried everything on this post |
| staffs964 Member Since: 21 May 2016 Location: Ontario, Canada. Posts: 11
Hi Nic
| Nic_101 Member Since: 31 Mar 2024 Location: England Posts: 13
hi,
I would try the fuses firstly, if the module won't talk to the old reader its possibly a blown fuse or fuse replaced in the wrong location which is an easy mistake to make, a bad battery can also cause a lot of issues too. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
I don't know if the L322 is similar to a D4 where the earth for the ABS module is nearby the ABS module. On my son's D4 it had been disconnected during an engine swap and not reconnected which caused a string of ABS-related comms faults. The tell-tale sign was that the IIDtool didn't list the ABS module as being fitted, so a power and earth trace was required. L405 D350 SE Carpathian Grey D5 19" rims |
| All times are GMT |
