Home > Technical (L322) > lost communication with abs module won't start
Bricey21
United Kingdom 2011 Range Rover Vogue SE TDV8 Barolo Black
Did you get this resolved? I have a very similar issue with my 4.4 tdv8 and have tried everything on this post
Post #693564 29th May 2024 1:35pm
Nic_101
United Kingdom 2011 Range Rover SE TDV8 Java Black
hi,
it turned out to be the abs fuse within the fusebox behind the glovebox, it is easy to put it back in the wrong place too, the fuse diagram has to be turned clockwise 90 degrees before reading it I think.
there are fuses behind the battery which corrode too worth checking those
Post #693592 29th May 2024 8:34pm
staffs964
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
Hi Nic
I have the same fault codes on my LHD FF SC. It's not the ABS module, I changed that.
You said the fuse box is behind the glove compartment. I wonder if I missed something, as my ABS fuses (box) is in the engine bay. Did you access the fuse behind the glove box inside the car or behind the battery?
Cheers, Mark Brit in Canada
RHD 03 FF Td6
LHD 11 FF SC
LHD 12 FF SC
Post #717323 3rd May 2025 4:16pm
Nic_101
hi,
the lower pat of the glovebox folds down once open revealing the fuses however this is on a RHD one im unsure if this is the same on a LHD, but there is a fuse behind there for the ABS module, other people give the fuse number in other threads I cant remember sorry. however be sure to replace the fuse in the right holder once checked as there was empty ones next to mine.
Post #717414 4th May 2025 10:44pm
Nic_101
I would try the fuses firstly, if the module won't talk to the old reader its possibly a blown fuse or fuse replaced in the wrong location which is an easy mistake to make, a bad battery can also cause a lot of issues too.
Post #722612 9th Aug 2025 9:25pm
GraemeS
Australia
I don't know if the L322 is similar to a D4 where the earth for the ABS module is nearby the ABS module. On my son's D4 it had been disconnected during an engine swap and not reconnected which caused a string of ABS-related comms faults. The tell-tale sign was that the IIDtool didn't list the ABS module as being fitted, so a power and earth trace was required. L405 D350 SE Carpathian Grey D5 19" rims
Post #722626 10th Aug 2025 11:52am
